tips tricks advice for cam install please
Old Mar 29, 2012 | 06:14 AM
Lundee's Avatar
Lundee
So I've been told by a few people, the se pushrods will rub on the covers too.
Old Mar 29, 2012 | 06:35 AM
RICHIEMACK's Avatar
RICHIEMACK
I have never done it myself but have seen it done,my indy always uses the screaming eagle pins.,the pins are $35 from harley.i dont know if you are going with gear cams if not you might as well change your cam tensioner shoes to the newer ones or upgrade to the se camplate with hydraulic tensioners,kind of pricy,thank god mine was upgraded when i bought it..its a long job ,and the right tools are a must but you will save $500 in labor,,good luck
Old Mar 29, 2012 | 06:52 AM
cwsharp's Avatar
cwsharp
What would be cool is that a couple of DIYers get a few sets of tools and pass them around for a few bucks. Online DIY tool rental. Deposit plus rental, deposit goes back into your Paypal... wish I wasn't spending all my spare change on my Harley or I would do it! <grin>
Old Mar 29, 2012 | 07:29 AM
Fierofly's Avatar
Fierofly
There's A guy on E-Bay that will rent or sell the tool for the inner cam bearings $35 to rent $105 to buy. I bought, worked great.
Old Mar 29, 2012 | 08:46 AM
rrambo's Avatar
rrambo
I just did this on my Lo.
The cam install was easy, I replaced the inner bearings but I bought the Jims bearing remover and installer..
For the oil pump, I just loosened the bolts a little.. arranged the flats on the inside to match the crank.. then wiggled the cam plate back on carefully.. after that, tighten the oil pump bolts.
Old Mar 29, 2012 | 08:58 AM
Uncle Larry's Avatar
Uncle Larry
Originally Posted by Lundee
Your correct about the conversion kit. However it is highly recomended you change your inner cam bearings to torringintons. For that you need the remover/installer. Alot of indies will rent you them for $20 or so + deposit. I domt think hd makes a quick install pushrod, so you will have to go in from the top, or like you said, the tappet blocks.
http://www.harley-davidson.com/gma/g...bmLocale=en_US
Here's a link to the HD adjustable pushrods
Old Mar 29, 2012 | 09:11 AM
soft 02's Avatar
soft 02
Here's all the video's for doing a big boar (not that you are doing a big boar). cams and pushrod info too!
http://www.fuelmotousa.com/107kit.htm
Old Mar 29, 2012 | 11:43 AM
SlkTxn's Avatar
SlkTxn
I rented the bearing puller from AutoZone for about $15...
Old Mar 29, 2012 | 03:29 PM
challutz's Avatar
challutz
Thanx everyone lots of good info here. I will get the puller and installer from Georges tools and the torringtons. I have the oil pump pins on the way with the conversion kit and cams. My pushrods came in already and according to instructions they go right in without removal of tappet clocks or rocker boxes. They are the straight not tapered adj pushrod. Part number 17997-99a, just waiting for the rest of the stuff now.
Old Apr 2, 2012 | 07:42 AM
Sandcrab's Avatar
Sandcrab
Default Expensive tools
The cam install was easy, I replaced the inner bearings but I bought the Jims bearing remover and installer.....
I have been looking at T/C inner bearing removal and installation tools, and JIMs tools are so much more expensive ($195+$159). I checked Ebay and there are two vendors selling both the installation and removal tool as one kit for around $109 plus shipping. Is the JIMs better or more precise or more accurate? I just can't figure out why such a big price differential? Anyone know??
