Auxiliary lamp independant control wire harness question
Old Apr 22, 2012 | 10:56 AM
Alter's Avatar
Alter
Default Auxiliary lamp independant control wire harness question
I just bought one of those auxiliary lamp independant control wire harness kits from the dealer and went outside this morning to see whats its going to take to put it in and OMG what a hassle it looks like. I chased the front fender light wire and it ends up under the tank. I began googling and reading in how I can get this thing on, ended up in the touring section but no help on my 04 heritage.
OK my question is that can I remove the front and back bolts on the gas tank and lift it up a bit to see under it and try to pull the connectors into view without having to go thru all the hoops of removing the tank all together as I saw in a pic in the touring section. I don't want to do the homemade version of splicing and I spent the bux on the harness, and I don't want to go to the dealer if I can avoid it.
Old Apr 22, 2012 | 11:53 AM
Daddy-O's Avatar
Daddy-O
Yeah, you can do exactly as you said. Just slip the tank back a little and the connector should be visible.
Old Apr 22, 2012 | 12:06 PM
BARACU's Avatar
BARACU
Big Kahuna HDF Member
On my 2012 Heritage , that connector was tucked in at the front of the tank. No need to involve loosening the tank at all.
Old Apr 22, 2012 | 12:29 PM
NC D'LUXE's Avatar
NC D'LUXE
+1 at least give that a try and see if gives you enough access to the harness. Just watch when putting the tank back down that you don't push down the front to hard and scratch the top of your rocker cover...don't ask how I know this.
Old Apr 23, 2012 | 06:39 AM
Tampa Fatboy's Avatar
Tampa Fatboy
Its a piece of cake. Remove both front and rear tank bolts, disconnect the fuel line, gently lift and pull the tank back. BR has a video walk you thru the process.
http://www.youtube.com/watch?v=LEE2R...0e536097761ca3
Old Apr 23, 2012 | 08:35 AM
KumaRide's Avatar
KumaRide
To be safe, put a piece of cardboard on top of the rocker covers so they dont get scratched.
TickTock
May 17, 2024 08:32 PM
Berick
Mar 31, 2015 09:56 AM
HarleyJeepMan
Mar 11, 2015 01:20 PM
jefkat2
Jun 6, 2012 04:30 PM
reesestewww
Sep 13, 2011 03:34 AM
