Running Wires Under the Gas Tank?
After searching for a but and not finding the the answers I'm looking for thought I'd post this out there with a very specific topic. Hopefully helps the next person.
I have a 2010 FLHR. Is this a difficult process? Any tips and tricks I should know before I begin? Leads me to my next questions, where do I start? I just need to run a small accessories harness under the tank. I'm hoping I can just lift it slightly and run the wire underneath.
Any pointers would be appreciated.
Thanks
R
Thanks
R
I'd strongly suggest that you remove the tank entirely (very easy job, since the 09-later [maybe 08-later; don't know] models don't have a crossover tube at the front). The factory wiring is contained within a plastic tray that runs down the frame backbone. You can open this tray (has a cover) and place the wire inside. This is a much cleaner solution than running the wire outside the tray, where it might be chafed by something else.
on my 1995, with seat off, I ran a thin piece of wood dowel under the tank to a point the right side of the neck.
attached the wiring I wanted to run and a small piece of cable which was to stay in place should I need to fish anything else through.
pulled the dowel back slow and easy--- and done.
I left my tank in place.
if you can't get a clear shot through, you may need to raise the rear or the entire tank.
Mike
Mike
+1. Best way is always the sure way to eliminate any future potential problems.
The gas tank is easy to take completely off on 2009 and newer.
Because there is only a quick coupler fuel line now, not a cross over in front like in the past years.
Then there is a plastic tray to lay your wires in and not have to worry about pitching the wires.
I am neither patient, a mechanic nor can I see worth a damn and I have done it.
I am getting better about being patient though.
