Springer Riser Question
Old Apr 23, 2012 | 07:09 AM
harleyriderny's Avatar
harleyriderny
6th Gear
Default Springer Riser Question
Quick question. Just did my 16" apes and noticed after I completed the install that the risers move slightly back and fourth. Are there rubber dampeners on the stock risers that allow for movement or should I pull the bars and the risers off and check? Never really noticed it with the low bars.Thanks L&R
Old Apr 23, 2012 | 07:52 AM
hspring03's Avatar
hspring03
Yes.. The stock risers have rubber bushings, which after time will have a lot of play.
Good N Tite makes poly bushings, which will take the play of them.
Drag Specialties has the good n Tite ones
Old Apr 23, 2012 | 09:11 AM
Iron Butt Springer's Avatar
Iron Butt Springer
Just ordered a set last night... Good N Tite
Old Apr 23, 2012 | 10:11 AM
Skeezmachine's Avatar
Skeezmachine
That is normal. The stock mini apes on my Crossbones give a bit more leverage and you can feel the risers move. Never really bothered me...
Old May 7, 2012 | 03:03 PM
bc419's Avatar
bc419
I just swapped out the stock mini-apes for Flanders Bad Boy style handlebars. While I was doing so, I replaced my riser bushings with the recommended Gooden Tight bushings as I had movement in my risers as well. (They may not bother everybody, but I didn't feel safe with any sort of play in there, & wanted everything tight).
At first inspection, these are a lot better than what HD put in there originally. The bushings are a lot beefier. And so far (after a few miles), they feel solid, & there is no play in the risers.
I would recommend anyone thinking about changing out the stock springer riser bushings (the stock ones are crap).
Thanks,
brian
Old May 7, 2012 | 03:48 PM
brettnbama's Avatar
brettnbama
I have gooden tites on mine, rock solid....
Old May 7, 2012 | 05:25 PM
Skeezmachine
Funny. I never notice the movement under normal operation. I only notice it when I am muscling the bike around in the garage by the bars. Just curious as to how much of the movement the rest of you feel to worry about how unsafe it is?
Old May 8, 2012 | 10:19 AM
bc419's Avatar
bc419
I had about 1/8" movement (maybe a little more). I mostly noticed it when I would move the bike around in the garage too, but I could tell when I was riding.
I first noticed it when I brought home (from just buying it). I was riding on the highway, & let go of the left handle. The moment I did that, the handlebars would start to shake. I knew something wasn't right, so I got on here & did some research. I first tried tightening down the bolts inside the risers, but realized they would need to be replaced.
For $60, it was a safety issue for me. Peace of mind also goes a long way! :-)
bri
Old May 10, 2012 | 10:00 AM
Hibrion's Avatar
Hibrion
I have 16 inch wild ones on my springer and they have a bit of play in them, but I like it and there are no vibrations to be felt. I wouldn't worry about it at all, mate.
BikerTMO
Apr 12, 2013 06:29 AM
acman308
Feb 25, 2013 06:23 PM
spooneralmighty
Jun 12, 2012 03:39 PM
bikerlaw
Jun 17, 2011 06:55 AM
matt816
Mar 26, 2009 11:58 AM
