Outer Primary issue
Old Apr 25, 2012 | 05:29 PM
94-Sporty's Avatar
94-Sporty
Default Outer Primary issue
Guys,
I have done a lot of troubleshooting on my bike in the last couple of months tracking down a leak..there were several threads here on it.
Well today, while doing some routine inspections I noticed that the top bolt in my 3 hole derby cover would not tighten in the primary. It appears that over time the aluminum mat have stripped. I moved the bolts and am sure the issue is the top bolt mount in the 3 hole primary.
Any quick and safe fixes other then replace the outer primary?
a larger diameter bolt ? i think the mount would probably be too fragile to retap..
Any thoughts or suggestions appreciated.
Old Apr 25, 2012 | 05:33 PM
Dawgtraxx's Avatar
Dawgtraxx
Helicoil?
Old Apr 25, 2012 | 05:42 PM
ghostrider69's Avatar
ghostrider69
Yep, Helicoil.
Old Apr 25, 2012 | 06:04 PM
94-Sporty's Avatar
94-Sporty
I have heard of it.. usually the local jiffy lube is doing it after messing up a buddys truck.
Whats the process and can I do it in my home garage ?
Old Apr 25, 2012 | 07:34 PM
94-Sporty's Avatar
94-Sporty
anyone know the thread size on one of those bolts for the derby cover
Old Apr 25, 2012 | 07:42 PM
RFG7680's Avatar
RFG7680
Its likely 1/4_20. Take the bolt to the hardware store with you. Show the guy and hell set you up. You'll need to look on the tap that comes in the kit for the proper bit size. For a 1/4-20 bolt you'll need I believe a 17/64 . drill it out, run the tap through (use some oil on it). Run the helicoil into it snap of the tab and your set. I'd use red lock right on the helicoil. Use regular blue on the bolt. Should be a 10 minute fix. If you do it with the cover still on the bike stuff rags in there so no shavings get in the primary.
Old Apr 25, 2012 | 07:44 PM
94-Sporty's Avatar
94-Sporty
RFG, thanks .. thats what i was looking for.
Old Apr 25, 2012 | 07:48 PM
RFG7680's Avatar
RFG7680
Just did the same fix on the inspection cover on the primary on a 99 fatboy. Worked nice. Just take your time. There's no rush.
No problem.
Old Apr 25, 2012 | 07:49 PM
soft 02's Avatar
soft 02
Yes 1/4 20 and you need to get a small kit that has the drill bit, tap and coils. Repair is far cheeper than replacing.
Khshockey44
EVO
May 2, 2015 08:40 PM
Bushy
Jul 22, 2011 07:28 PM
parakiller
Apr 27, 2009 10:33 PM
blackfinbob
Aug 1, 2006 10:33 PM
kylefaulk20
Dec 19, 2005 01:53 AM
