Installing new clutch & Brake levers
Old May 1, 2012 | 07:37 PM
Mr.Softy's Avatar
Mr.Softy
Default Installing new clutch & Brake levers
I thought tomorrow I would go and buy a set of chrome levers for the clutch and brake. Tonight I am reading through the service manual and see a 5/32 cardboard insert for the brake lever. Do these come as part of the lever package or do I need to buy it separately?
I didn't see anything that seemed difficult about the clutch lever install, did I miss it or is it that easy?
This is the first time I am going to do this and don't want to leave the bike unable to be ridden, I am not very mechanically minded. I have a set of retaining ring pliers will I need anything else?
Old May 1, 2012 | 07:47 PM
ghostrider69's Avatar
ghostrider69
You just have to be careful when changing out the levers because of the brake light switch on the right side. I am sure your bike also has a clutch safety switch on the left side. These switches are easily damaged if care is not taken.
Old May 1, 2012 | 08:30 PM
jreichart's Avatar
jreichart
You can just use a standard piece of cardboard. I swapped mine out and didn't even know to be careful of the switch, and didn't have any issues at all. Just be easy on them, and be mindful if they snag on something don't just pull harder.
Old May 1, 2012 | 08:33 PM
Cygnusx51's Avatar
Cygnusx51
If you look at the brake lever when you buy it or remove your current one, you'll see the protrusion that presses on the brake light switch. When installing the lever, many people snap off the switch with this part of the lever. The cardboard just keeps the protrusion from tearing the rubber boot and breaking the switch. This is what the switch looks like:
Old May 1, 2012 | 08:36 PM
jimmers1817's Avatar
jimmers1817
Just swapping out levers should be a piece of cake. I've had the clutch lever off but not the brake. FAIK, the piece of cardboard is only used when you're disconnecting the switch controls from the brake lever. It's keeps the lever open a tad to prevent damage to the brake light switch under the lever. But if you're removing the lever I don't see how the use of the cardboard shim would be applicable. Maybe someone else can give a more definitive response.
Old May 1, 2012 | 08:38 PM
QC's Avatar
QC
Piece of cake! Cut a piece off a heavy cardboard box same width as the lever and about an inch long. Squeeze the brake lever and stick the cardboard in there. Just be gentle, it's really pretty easy. Never did it B4 I did it. Should take less than an hour if you take your time. Have fun! This is one of the fun parts of ownership. Learning new stuff about your machine and YOU!
Old May 1, 2012 | 08:50 PM
jimmers1817
But if he's taking the brake lever off, what's the point of putting the cardboard shim behind it? Curious to know the answer.
Old May 1, 2012 | 09:41 PM
QC's Avatar
QC
Just to keep you from bangin the switch around. That's all. The switch itself is only held in there with a small V-shaped spring at least on my '04. Pretty fragile set-up.
Old May 2, 2012 | 05:49 AM
Mr.Softy's Avatar
Mr.Softy
Thanks guys!
Old May 2, 2012 | 06:45 AM
In Memoriam Citoriplus's Avatar
May our Moderator Rest in Peace
Monkeying around trying to put the lever back in without the cardboard to prevent the lever from pressing sideways on the plastic plunger is a recipe for a broken switch.
Way too many guys have discovered that the hard way, so if your ever messing around with the levers, take a minute to make and use the cardboard.
It'll save you some money and a whole bunch of aggravation.
