oil in sump help!
Old Jan 3, 2007 | 04:00 PM
BTROUT's Avatar
BTROUT
Default oil in sump help!
i have an 06 softail deluxe. i put my bike away for winter
2 months ago, i changed the oil at that time and brought
it up to normal levels. i was doing some work on my scoot
today and because i heard softails will drain back into the
sump i checked my oil. it did drain into the sump as i just have
oil up to the fill level showing. my question is, if when i fire it
up in the spring is it safe to do so if there is no oil in the tank?
thanks
scott
Old Jan 3, 2007 | 04:33 PM
baitrunner's Avatar
baitrunner
Default RE: oil in sump help!
yes it's safe. once you fire it up again, the oil level in the tank will go back to normal. it is for this reason that you're supposed to check oil levels when the bike is warm.
8541hog
Jun 28, 2022 04:42 PM
mballard
Shovelhead
Sep 13, 2012 03:32 PM
dandanny81
Jul 29, 2012 12:18 PM
FroggyFatBoy
Feb 28, 2011 04:07 PM
dcdr
Oil Archive (no new posts)
Mar 12, 2010 03:58 PM
