BCM Body Control Module Problems 2012 Softail?
Old Sep 8, 2013 | 05:45 PM
  #31
devildocjames's Avatar
devildocjames
Hey fellas, what was the outcome? Just got a new 2013 Wide Glide and has the same problems as the OP. Sputtering, backfiring, and cutting out. The techs can't find anything wrong. It's random and not always a complete power down. It sucks, because, I bought it off the floor two nights ago and haven't even finished my first tank of fuel.
Old Sep 10, 2015 | 03:49 PM
  #32
JustDave13's Avatar
JustDave13
I had an issue with my BCM today. While riding I noticed my batt. check engine, abs and security light on. I also noticed the speedo and display stopped working.
I turned into a parking lot, hit the kill switch and nothing happened..the bike kept running. I turn off the ignition and the bike eventually stalled after 10 seconds or so.
I checked and cleared a couple of lost comm BCM codes and now everything seems to be working fine.
I guess I'll have to see how it goes.
Old Apr 27, 2016 | 11:37 PM
  #33
JustDave13's Avatar
JustDave13
Well I seen how it went. I took the bike out today for a ride and the problem came back. (mileage 24,9**)
Codes were..
U0001 CAN Buss error
U0140 Lost comm BCM
U0141 Lost comm LHCM (left hand control module)
U0142 Lost comm RHCM (right hand control module)
U0156 Lost comm to speedo.
One thing I did notice was that after all those lights lite up (my prior post) that the whole speedo went dark.
The bike still ran fine but I had no directionals (hand controls) and no speedo.
Another thing I noticed was the both trip meters reset to zero but the clock held its time, also the fuel gauge still worked
I'll spend some time on the bike tomorrow and post what I find.
Old May 7, 2017 | 04:22 PM
  #34
cempty808's Avatar
cempty808
4th Gear
Default Problem resolved?
Codes were..
U0140 Lost comm BCM
I know its been awhile, but my 14 have these same codes. Wondering what you found to fix the problem. Thanks
Old Nov 11, 2019 | 08:31 PM
  #35
James Palacios's Avatar
James Palacios
Stage I
In reference to post back in '15 by JustDave13, did you ever figure out what the problem was? Was it the BCU? I have a '14 heritage just like cempty808 who commented in '17 trying to figure this out too. None of my speedo functions work so I can't even get into the "code mode" to figure out what is going on - it went totally dark and has stayed that way since this started. Otherwise similar systems that JustDave13 and cempty808 seemed to have. Headlights come on, no turn signals, nothing what-so-ever on the speedo, won't turn over at all. Had a bad battery and a bad voltage regulator which I replaced (both) already. Other strange system is that the ABS module solenoids keep engaging i.e. clicking away non-stop even with the ignition off. I had to disconnect the battery to get them to stop. Any help would be greatly appreciated!
Old Jan 31, 2020 | 03:32 PM
  #36
blackspider16's Avatar
blackspider16
Default Same problem
James Palacios,
Did you find a solution for your issues?
I have a 2016 FLSS (Softail Slim S) with 24k miles now (bought new in 2016) and started having the same issues a few months back. I took my bike to one dealer that had it for over 1 month and finally claimed it was fixed. I picked it up from the dealer and drove 22 miles, and it had the same issue. I paid 500+ and they didnt fix it, I decided to take it to another dealer and they fixed it in 2 weeks.
They replaced BCM, ECM, ABS sensor, and it seemed to fix it for 1100 miles and now as of yesterday, same problems.
NOTE: with the ignition on, all lights in speedo illuminate, WONT start, WONT turn OFF (I have to remove main fuse), I get 'BUSSerr' in the LCD display, headlights/AUX/tail work, turn indicators DO NOT work, rear break light works with foot pedal but DO NOT with front break leaver. With the bike OFF, there is a clicking sound (like relay) in the ABS unit under front forks --> im sure that is one problem that drains the battery as I have replaced 4 since I bought the bike. (I do use a battery tender.)
I will be taking it to the dealer next week and hopefully have an update / solution.
Old Feb 1, 2020 | 06:11 AM
  #37
niv's Avatar
niv
Originally Posted by blackspider16
James Palacios,
habe they also installed a new voltage regulator? I had, on a 2012 bike, all the problems that point towards faulty BCM, but went for the regulator first, which miraculously fixed it all. My next step would have been the alternator... can highly recommend Cycle Electric stuff.
Best, niv
Old Feb 1, 2020 | 06:57 AM
  #38
blackspider16
niv,
Funny you mention voltage regulator, yesterday I took the voltage regulator off to clean it up and I found oil in all the connectors that are attached to the voltage regulator bracket. I guess the last time the dealer did the oil change, they let oil pour all over and did not clean it up. I will look into testing the voltage regulator today.
Old Feb 1, 2020 | 10:04 PM
  #39
niv's Avatar
niv
I was told that too much dirt and other stuff on it would reduce the cooling fins ability to, well, cool the unit, which could result in permanent damage. But I guess if the connectors are dirty, it could have a similar effect, hopefully without damaging the unit. looking forward to hear from you about it.
kbird70
Aug 24, 2017 04:05 PM
Mcarso1
Apr 21, 2015 09:23 PM
nightie
Dec 12, 2011 06:42 AM
Aldra
Feb 17, 2008 04:42 AM
jmb2232
Sep 11, 2005 06:26 PM
