charging problems on my 99 night train
Old May 15, 2012 | 06:37 AM
soldier of fortune's Avatar
soldier of fortune
Default charging problems on my 99 night train
ok so i replaced the battery in the night train cause it boiled all the water out of the walmart battery, and i just thought that it was the walmart battery, however i replaced it with a harley battery. and the other day when we were on a 200 mile ride, i smelled the acid in the harley battery. like the walmart battery, and today i went to ride to work and it is dead again, any ideas on this problem? not sure if this is related,but half the time my speedo doesnt work, not sure if this is related or not. thanks for any help you guys can give.
Old May 15, 2012 | 10:45 AM
MaxxdOut's Avatar
MaxxdOut
The two issues are likely related. I recommend that you preform some voltage tests. My guess is you have a stator or regulator issue.
Old May 15, 2012 | 04:37 PM
chromefatty's Avatar
chromefatty
Had the exactsame problem on my 99 faboy last summer. I replaced the voltage regulator and have had no issues since. I"m pretty sure it was around $130 and took less than an hour. Good luck
Old May 15, 2012 | 07:47 PM
Dragon318's Avatar
Dragon318
Sounds like you're overcharging, bad voltage regulator. Simple to test with a cheap voltmeter.
Old May 15, 2012 | 09:59 PM
soldier of fortune
thanks for the info guys, i will check the regulator first.
jj5685
General Topics/Tech Tips
Jun 22, 2015 11:41 AM
soldier of fortune
Electrical/Lighting/Alarm
May 18, 2012 06:51 AM
soldier of fortune
EVO
May 15, 2012 03:30 PM
agapsdiver
Oct 18, 2008 11:02 PM
Ed C
Dec 17, 2006 08:29 PM
