Help lowering 2008 Fatboy
Old May 15, 2012 | 09:48 PM
wcjr's Avatar
wcjr
Default Help lowering 2008 Fatboy
I am interested in lowering my 2008 Fatboy.
At the moment I am not able to flat foot on the ground, I am only able to touch with the tips of my toes (I'm 5'8").
It would make me fill more comfortable if I were able to completely flat foot when sitting on the bike. My friend has a 06 deluxe and it is sitting at the perfect height for me.
What do you guys recommend. Keep in mind I am trying to keep it budget friendly. I am not interested in air ride, etc.
Thanks
Old May 15, 2012 | 09:57 PM
BB06FLHX's Avatar
BB06FLHX
Few options available.
Try a different seat with less cushion
Buy a set of lowering bolts and lower the rear. Bolts range on eBay but cheapest is around $16. I paid $25.
Old May 15, 2012 | 10:03 PM
jimmers1817's Avatar
jimmers1817
At 5'8" I could flat foot my Heritage with no problem but with the added height of my Mustang wide touring seat I decided to drop it down an inch. I found some low mileage Deluxe shocks cheap on ebay and put them on. Dropped it an inch without much if any noticeable difference over bumps.
I ride solo 99% of the time. If you do alot of 2 up riding you may notice the lower shock travel more.
There are kits you can buy that will drop it an inch or so that are less expensive than going to Deluxe shocks. I can't remember what I paid for my shocks but I think it was around $50. A bit of a pita to install as I recall but certainly within the realm of the average DIYER.
Old May 16, 2012 | 04:48 AM
wcjr's Avatar
wcjr
Thanks for the idea on the deluxe shocks! I am wanting to keep the ride as stock as possible.
Do the lowering bolts affect the ride quality too bad?
Old May 16, 2012 | 05:36 AM
Blk and Chrome's Avatar
Blk and Chrome
There is everything from bolts to shocks to airride. Bolts are cheap $20-100, shocks $400 and up and airride up to $ 1500. The seat is the best place to start for most and does help a lot
Old May 16, 2012 | 05:37 AM
urbancamo's Avatar
urbancamo
My wife has the same bike, she's about 5'4 and a stock fat boy lo seat put her flat footed.
Old May 16, 2012 | 08:21 AM
jimmers1817
I don't have any experience with them but I think they work by extending the shock travel and if that's the case then you're looking at a bit more bottoming out on railroad tracks and the like. Not a big deal for me.
The bolts would be the cheapest way to go and they might be easier to install than swapping out with Deluxe shocks. Maybe someone who has them can chime it or you can do a search for some older posts.
Old May 16, 2012 | 08:26 AM
suiii15's Avatar
suiii15
Bolts are more work than swapping shocks, as to install the bolts you have to remove and dismantle the shocks anyway. I'm 5'6'' and I can flat foot my brother's 2007 fatboy so maybe you just have a huge couch seat on that thing. Bolts do reduce ride quality, but it might not be a bad thing if it will give you better confidence when riding the bike. Not being able to flat foot a heavy bike is a scary feeling.
Old May 16, 2012 | 09:32 AM
Benway's Avatar
Benway
I ride two up occasionally and we only bottom out once in a while with the 2" lowering bolts. Otherwise, I can't tell the difference unless I hit something big. Then I get a 'bump', but I used to ride a hard tail, so no biggie for me.
Depending on how big the 'little lady' is, your mileage may vary... (pun, get it?)
+1. How people can tippy-toe these big twins without falling over at the slightest rut in the road is beyond me.
OP, I've got a thread around here titled "best $16 I ever spent" that shows how to install the bolts without a press...
Old May 16, 2012 | 09:52 AM
Tampa Fatboy's Avatar
Tampa Fatboy
+1 on the seat swap. FB wide **** seat sux. I went with the C&C solo and not only much more comfortable its going to give you that flat foot reach you're looking for. Lowering the bike is usually reserved to those that want to go with taller wheels. The shock comment is also another plus but I'd start with the seat first.
