tire sizes ?
Old May 18, 2012 | 08:36 AM
MSG Hall's Avatar
MSG Hall
Default tire sizes ?
I want the biggest, tallest, fattest most bulbest tires I can fit under my fenders... and if'n I gotta bend the fenders a bit to fit them in, it wont hurt my feelings at all...
02 Heritage Springer... what size do you guys think?
Old May 18, 2012 | 12:24 PM
oct1949's Avatar
oct1949
depends on how much room U have between U belt and tire. U'll usually rub there before rubbing the fender.
measure that and then look up some tire Specs to see what will fit.
Rule of thumb is U can go 1 size and be safe. but not always
Old May 18, 2012 | 01:09 PM
hspring03's Avatar
hspring03
140 is the max you can put under a Heritage Springer 02 with out making some adjustments.
You can put a 150 if you get the fender nut kit found in the 03. Even then it will be tight and has a possibility of rubbing depending on tire manufacturer.
Old May 18, 2012 | 02:36 PM
suiii15's Avatar
suiii15
Stole this from Benway
http://www.hdwheels.com/Product.htm
Old May 18, 2012 | 02:57 PM
SprungDave's Avatar
SprungDave
Dunlop MU85B16 WWW in the rear (a 140 wide) is a perfect fit. No rubbing or mods necessary. You might be able to get a 140 wide WWW for the front, but the stock MT90B16 (130) fits about perfect.
Old May 18, 2012 | 06:34 PM
ejvette's Avatar
ejvette
I'm luvin the 200 rear tire on my new sled...I highly recommend it if you can force it in
HeritageBill
Mar 25, 2018 12:53 PM
Infamouz
Wheels/Tires
11
Apr 25, 2017 04:10 PM
MSG Hall
Sep 10, 2012 02:45 PM
magnum629c
Feb 26, 2010 08:22 PM
tlsmith22
Oct 4, 2008 11:42 PM
