Leather care
Old Feb 27, 2015 | 12:05 PM
  #31
01fxdxt's Avatar
01fxdxt
Originally Posted by Ron750
Not an urban legend. From http://www.manualslib.com/manual/768....html?page=119
"Do not use any silicone-based protectants. They will extract the plasticizer, leaving vinyl hard and brittle, and eventually cracking will occur."
It is right in my owners manual. Any good marine shop knows this. You are the one full of BS.
Recommended Products
MasterCraft Vinyl Dressing
Vinyl Finish Vinyl Cleaner
Mild Dish Soap
303 High Tech Fabric Guard™
Non-Recommended Products
ArmorAll
Bleach
Baking Soda
Fantastik
Formula 409
Murphy's Oil Soap
Simple Green
Son-of-a-Gun
Armor all is water based...
http://www.armorall.com/faqs/interio...m-distillates/
so,suck it
Old Feb 27, 2015 | 01:33 PM
  #32
01fxdxt's Avatar
01fxdxt
Originally Posted by TOWGT
http://www.autogeekonline.net/forum/...165602663TOGWT vbmenu_register("postmenu_103521", true);
Senior Member
Silicone: Not to be confused with the element silicon
The degree of polymerisation [process of bonding monomers, or single units together through a variety of reaction mechanisms to form longer chains named polymers] determines the physical form of the silicone, which can vary from thin oils to relatively hard rubbers or resins.
The myth of grouping all silicones into one category and label them harmful; environmentally unsound or dangerous is just that, a myth, and like most myths there is some, albeit little truth to it Making an all encompassing statement that products that contain silicone are harmful shows a lack of any real knowledge of the petroleum refining processes; these irresponsible statements are purely misinformation at best, and are meant to mislead or to be used as negative marketing.
Silicones are primarily used to modify or improve certain characteristics; they are sometimes added as a lubricant to provide spread ability thereby making a product easier to apply. The automotive industry uses silicones as component parts (see polymerisation) in its plastic, vinyl, rubber, paints, and fibreglass as well as in polishes and waxes.
Silicone (Siloxane)oils provide an excellent lubricant that when used as a carrier system in polishes that makes them easier to apply and remove When used in paints and other coatings it ensures an even flow through a spray nozzle ensuring an even product distribution.
The low surface tension of some silicones improves automotive cleaning products by increasing the ‘wetting’ ability by providing a much better surface contact for abrasive or solvent type cleaners and polishes. The newer amino functional silicones when added to products create a physical bond with the surface; this boding provides better product durability than products that rely only on surface tension for bonding.
Petroleum distillate silicone oils and solvents are often used in a water-in oil emulsion (water-based silicones) as a delivery method (carrier system) for the protective components of a product. The oils also help the product to spread and then the solvents vaporize (outgas) to enable product residue removal. Solvents evaporate more efficiently, especially at low temperatures than water-based products, which require heat to vaporize. Silicone oils are inherently water repellent so they won’t allow water to compromise the paint surface providing better durability and protection. Because of silicones ability to refract light it also provides a ‘brighter’ shine.
Information resource:U.S. Environmental Protection Agency website, Department of the Environment (DOE), EPA/Purdue University Study 2001 -79 The American Association of Industrial Hygiene (AAIH) American Petroleum Institute (API) publications The Basics of Silicon Chemistry - Dow Corning. http://www.eng.buffalo.eduChemical definitions by Main Page - Wikipedia, the free encyclopedia
Reference source- Automotive Detailing Inside & Out, A Knowledge Base for the Perfectionist – by Jon Miller aka TOGWT™ Š 2004 – 2007 all rights reserved
As a chemical Engineer (ChemE) I would like to help detailers reach an intelligent and logical understanding of the many chemicals used in detailing. Improperly used chemicals can cause damage to the surface they are applied to (sometimes irreparably) because the detailer was not educated regarding the chemical make-up of the products they used.
Conversely I also want to show you that it's a waste of time to dedicate too much time and attention to them. All that is required is that you learn some basic chemistry i.e. what pH values mean, and what detailing chemicals too avoid or the precaution to take if you do choose to use them.
Good Silicone / Not so good Silicone:
a) Water - based silicone dressings, usually a milky-white liquid, (Polydimethylsiloxane (PDS)that doesn’t contain petroleum distillate; silicone oils, waxes, or solvents that can harm rubber and/or vinyl over time. Water-based dressings use a combination of natural oils and polymers to offer a non-greasy, satin finish. Some of these products also contain ultra violet radiation (UVR) blocking agents to help keep tires from cracking, fading and hardening. Most, if not all water-based dressings are biodegradable (i.e. Zaino Z-16 Perfect Tire Gloss™) whereas silicone is not.
b) Solvent-based silicone dressings, usually a clear greasy liquid, (Dimethal (DMS) that contain petroleum solvents as a cleaning agent, they remove the elasticity from vinyl, rubber and paint; causing them to evaporate out of the substrate, leaving behind a dry inflexible surface. The difference between water and solvent based is in the carrier system used. Solvent based products use a hydrocarbon silicone to suspend the product. When you apply it, the solvent evaporates leaving the dressing's active ingredients (Silicone oil) behind; this type of silicone is also not biodegradable. Most high gloss products are based upon DMS silicone oil.
Old Feb 27, 2015 | 04:26 PM
  #33
Ron750's Avatar
Ron750
so,suck it
You quote the manufacturers website. I will believe the boat manufacturer, who has no reason to lie. I ruined my original interior in a couple of years. After 10 years of using Aerospace 303 no cracking.
Old Feb 27, 2015 | 04:42 PM
  #34
01fxdxt's Avatar
01fxdxt
I think your boat info is talking about cleaning/cleaners.Armor all cleaning products may contain things (alchohol maybe) bad for certain fabrics.But I am referring to original protectant which people have been using for a long time with no ill effects.
Old Feb 28, 2015 | 05:58 AM
  #35
Pale Horse Rider's Avatar
Pale Horse Rider
Pure Neatsfoot Oil for leather.
Most of the leather products contain some.
Let it soak in and treat the inside and outside.
Not sure I would use it on my jacket though...
Old Feb 28, 2015 | 09:18 AM
  #36
HDmikie's Avatar
HDmikie
I've been using Corbin Saddle Cream. It's made by the company that makes bike saddles.
http://corbin.com/accessories/conditioner.shtml
LRS
Jan 30, 2011 06:23 AM
Hockey Stick
Dec 18, 2009 04:11 PM
Cloud09King
Apr 4, 2009 01:33 PM
BBQsauce
Oct 29, 2007 12:28 PM
ultraclassic137
Mar 15, 2006 12:32 PM
