Pulling Left
Old Jun 8, 2012 | 06:06 PM
ghostrider69's Avatar
ghostrider69
Mine has pulled to the left if I remove both hands since the day I bought it. I just lean a little to the right to compensate. I have been holding out on adjusting the axle until I change out the swing arm and wheels.
Old Jun 10, 2012 | 05:34 PM
jneubig's Avatar
jneubig
Originally Posted by bikerlaw
Its absolutely the correct solution! I have argued with more people on this forum who do not understand what axle adjusters do, or why they are even there. Kudos to your sir. If the bike does not track straight you adjust the rear axle adjusters, its as simple as that. If the bike tracks to the left, adjust the right adjuster. If it tracks to the right, adjust the left adjuster. Always keeping belt tension in mind as you make adjustments.
Thanks very much for the confirmation that what I did was the correct fix. It just seemed to me to be the logical thing to do.
Old Jun 10, 2012 | 09:22 PM
pumas9087's Avatar
pumas9087
So where are these adjusters? picture?
maybe a "how to " on doing this?
Old Jun 12, 2012 | 06:37 PM
Iceman68's Avatar
Iceman68
Mine will track straight with no hands if I put the right edge of the seat in my crack! Pretty seriously off balance. I asked my dealer about that right after I got it and they said about the primary being on the left and the weight being the reason... Puzzled me because my dad's Road King rides straight as an arrow with nothing ever adjusted. I did notice my belt rides ever so slightly off center of the rear sprocket though. I'll have to give the axle adjustment a try.
Old Jun 12, 2012 | 07:22 PM
bikerlaw's Avatar
bikerlaw
You have to get the rear wheel as close to being aligned as possible. You do this by loosening the axle and adjusting the adjusters. You can use a caliper or tape measure, but you need to get the axle ends to be as close to equal as possible to the rear of the swing arm on both sides. If a tech or the factory has been working on it, its probably pretty close. Once you measure the axle and get it as close as you can, you need to "fine-tune" it on the road. Easy to do...like this:
Once you have your belt adjusted and wheel as equal as you can determine...go for a ride on a nice level road on a calm day without a lot of wind...run it up to 35 or 40 mph...release pressure on the bars, basically to the point that your not even holding on to the bars and if everything is perfectly aligned it will track true and straight.
If it pulls to either side, that means the rear wheel is cocked slightly. If it pulls to the left, it means the front of the rear wheel is cocked to the right...if it pulls to the right, the front of the rear wheel is cocked to the left.
For example...let's say it pulls slightly to the right. That means the front of the rear wheel is cocked to the left (the left end of the axle is further back than the right end of the axle)....loosen the axle slightly and use the right adjuster to move that side of the axle back a turn. A little bit of adjustment can make a huge difference.
Hope this helps.
Old Jun 12, 2012 | 10:21 PM
pumas9087's Avatar
pumas9087
Thanks for the response and the brief how to!
Old Jun 15, 2012 | 06:32 PM
oct1949's Avatar
oct1949
Sooooo while U say to adjust the adjuster, But U can adjust them in or adjust them out.. So which way are U saying to adjust those adjusters.
If it tracked to the right wouldn't one have to adjust both adjusters not just the left adjuster to adjust the belt to keep it adjusted with the right adjustment tension and tracking correctly.??..
Old Jun 17, 2012 | 02:11 PM
londo-cat's Avatar
londo-cat
Hope this helps.
100% correct. Usually after I put on a new tire. I set the adjuster bolts 100% same-same. Then I take it for a ride. If the bike pulls left, It means the tire is slightly to the right, so I adjust the *right* adjuster bolt OUT 1/2 turn. I tamp the while and axle to make sure it's set against the adjuster bolt and re-lock the rear nut, then take it out for a short ride. Test to see if it pulls again.
If it still pulls left, I adjust another 1/2 turn OUT. Same to be said if it pulls right, in this case I adjust the right adjuster IN. I'm always adjusting the right adjuster until I get it to track right. I can usually nail it within one or two adjustments.
Old Jul 7, 2013 | 07:30 AM
mtadg0817's Avatar
mtadg0817
2nd Gear
I recently bought an '08 Anniversary edition Ultra and it has the same problem. My dealer told me the solution is not to ride with your hands off the bars, but I have to apply pressure on the right or pull on the left slightly to keep it straight. Would love to get this fixed but they don't seem too enthusiastic about looking at. Is this alignment adjuster on the rear wheel something that I can do at home, need a special tool, etc. I am used to working on my own bikes so this can't be too difficult.
Old Jul 7, 2013 | 09:52 AM
jam436's Avatar
jam436
My Slim does the same thing, and for reasons I still don't understand, the rear wheel is offset to the left under the fender... and it seems they're all like that.
The tracking is very slight, so much so that with both hands on the grips, I don't feel a thing.
It's only when I let go that it starts to drift left.
