Stability on bikes with 21" front tire
The reason I ask is that my Night Train does not seem as stable as it should be. In NASCAR they talk about a "tight" condition where the car does not want to turn, as i'm at higher speeds and lean into a turn, the bike seems to want to keep going straight, sometimes forcing me to slow while in the turn. I'm talking about regular hiway speeds of 60-70.
The last bike I had, had a much wider front tire and I had no problems. I'm going to replace the front tire, due to another issue, and go with a Metz hopeing this will help.
Anyone else had this?
I have a 06 Night Train. Only twice have I had stability issues. First was low front tire pressure - The narrow 21 inchers lose pressure quickly and you don't need to lose much to affect stability. The Second was highway riding with buffering cross winds - got a litte twitchy above 120k (about 80mph). A Fork Brace fixed that. So far no other issues. Problem could also be loss of a wheel weight or a faulty tire.
Just my thoughts.
Are your bikes with the 21" front tire stable on the hiway?
I agree low tire pressure and another thing I noticed I was subconciously sketched out about haveing A thinner tire up front and was scared to push it through a tight corner but found out it gos through corners like a breeze.If you are a newerrider counter streering is A beautifull thing, it took me a little while to figure it out . Youprobly already fig. that out . Not to mention my front rim is 3/4 of an inch offset!
I've experienced the same turning characteristics you've described at higher speeds and I noticed that the bikecorners easier when I shift my body to put more pressure into making the rear of the bike lean.The width of the 200mm tire changes the bikes handling in curves,it takes more effort.
TheSoftailsare also carrying about 40lbs more empty weight than nearly all of the Dyna's. We would even bother mentioning the Sportsters.
One thing more that hasn't been mentioned is that the Softails are lower and even a inch or too means a lot when your talking about the leverage your body mass can exert when you lean your weight over to turn or even shift lanes. Compared to a Buell or other"twisty" types of bike they are practically dragging their butts.
[IMG]local://upfiles/13603/47F137786E1A4ACA8C93D41B1F20AC4D.jpg[/IMG]
