loctite
Old Jan 9, 2007 | 01:06 AM
nitetrain's Avatar
nitetrain
Default loctite
So I just put the easy effort clutch kit in my 05 train and love it. My question is when I put everything back together I didn't put loctite on the header pipe nuts cause the manual didn't say to put it on,and it doesn't look like there was any there before.I torqued everything to specs, and after two rides now I had to retorque the nuts, I suppose from the heat. So should I put loctite on them or just keep my eye on them? Thanks for any advise,Gary
Old Jan 9, 2007 | 01:51 AM
darkside's Avatar
darkside
Default RE: loctite
No on the loctite for the exhaust flanges.Just about everywhere else though ,it's a real good idea
Old Jan 9, 2007 | 08:43 PM
billvaughn's Avatar
billvaughn
Default RE: loctite
Agree with above...No need on the flanges, just check them now and then.....
[IMG]local://upfiles/2670/0FDCA6A36B974026BC9A4DFCDA2E8C1B.jpg[/IMG]
Old Jan 9, 2007 | 09:15 PM
monkyman's Avatar
monkyman
Default RE: loctite
No lock-tite as stated, you should always recheck your exhaust flange nuts after 100 miles or so, if you had just installed them. Especialy if you replaced the gaskets.
Old Jan 11, 2007 | 05:29 PM
Sharknose's Avatar
Sharknose
Default RE: loctite
Might want to put some anti-sieze on them though....it's harder than hell to replace a broken exhaust stud when you twist it off flush with the head. I know from experience.
Malazan
Apr 24, 2019 12:04 PM
SmittyFXDL
Nov 20, 2012 07:25 AM
tinsley
Exhaust System Topics
Oct 19, 2010 04:24 PM
ken thompson
Apr 12, 2008 12:13 PM
ChiefGator
Shovelhead
15
Mar 27, 2008 11:43 AM
