Auto Tune or not??
Old Jun 11, 2012 | 08:05 AM
tlar1540's Avatar
tlar1540
Default Auto Tune or not??
This has probably been asked but I can't find a thread on it so I'm going ot ask and see what comes of it...
I have an 08 Heritage that I recently put V&H true duals on as well as a Mach II air cleaner & V&H Fuel Pak. My question is this; What would happen if I pulled the Fuel Pak off and just ran off the stock ECM? I have a buddy of mine that did this on his "07" Heritage & his bike seems to run better & his fuel mileage hasn't been effected. Is there any short or long term harm done to the bike if you try this? I know in the auto world, the computer self tunes itself to each modification that is made, why doesn't a bikes ECM do the same? It's still looking at the changes through the O2 sensors and other sensors and correcting what may be needed to run efficiently.
Would like to know your thoughts on this please!!
Thanks!
Old Jun 11, 2012 | 08:41 AM
2011Deluxe's Avatar
2011Deluxe
You would be fine. 2007 and later EFI does not require a tuner but about half of the people still think that you need one for just pipes and ac.
Old Jun 11, 2012 | 09:01 AM
redmosquito1's Avatar
redmosquito1
I disagree. My understanding is the O2 sensors are narrow band sensor and can't adapt to the big changes in fueling once the ac and pipes are changed. I may be wrong but on cars they typically use wide band sensors so it can adapt, but even then a lot of people put a tuner on to get the correct a/f ratio.
I'd say you should add a tuner, problem is most tuners like the power commander and fuel pack are just guessing at what you need unless you actually Dyno it and check the a/f ratio while doin it. So unless you dyno your guessing.
Old Jun 11, 2012 | 09:08 AM
MikeZ's Avatar
MikeZ
You'll run too lean and hot and you'll get a lot of decel popping.
Old Jun 11, 2012 | 09:09 AM
tlar1540's Avatar
tlar1540
Agree or disagree, would it hurt anything to try it without any type of tuner to see how it runs? And, if it runs better without a Fuel Pak or tuner, then why add one?
Old Jun 11, 2012 | 10:13 AM
Wide_Open's Avatar
Wide_Open
With both an exhaust and hi-flow filter you need a tuner or at least a download.
tpcowfish
Jul 24, 2015 05:25 AM
WideGlideFever
Feb 10, 2013 06:44 PM
ash uk streetbob
Jul 9, 2012 09:27 PM
Mimo951
Jun 17, 2012 10:30 PM
gdhugh
Oct 6, 2011 12:20 PM
