Tank reads empty...
Old Jun 18, 2012 | 12:17 PM
F22 Junky's Avatar
F22 Junky
Default Tank reads empty...
Just got my slim on Sat. Been riding around town a little bit. When we got back last night it was on E. Went to the Gas station this morning and filled up. Tank still reads E and says lo range. Any suggestions?
Old Jun 18, 2012 | 12:21 PM
Sgt_Jim's Avatar
Sgt_Jim
just on 1 tank of gas? sometimes it takes 2-3 for the computer to learn your riding style and figure what kind of range you'll get.. go through another tank, and if it still does it, read through the owners manual on how to do a computer reset which will zero out the range-o-meter and just go through the process again
Old Jun 18, 2012 | 01:06 PM
oct1949's Avatar
oct1949
New bike,,, don't fudge with it... dealer warranty work... ask them...
float may be stuck or elc issue?? either way or whatever it is I wouldn't mess with it.
Set Ur A or B mileage to (0) and refill at least every 150 till fixed.
Old Jun 18, 2012 | 01:11 PM
F22 Junky's Avatar
F22 Junky
Thanks. Gonna just watch my mileage until i can drop it off and get it fixed.
Old Jun 18, 2012 | 01:12 PM
jayzee75's Avatar
jayzee75
Mine worked for a couple months when I first got the bike. After that I has the exact same problem as you. The dealer ordered me a new speedo (I'm still waiting for it).....before I got the new one in, it started working again.
Old Jun 18, 2012 | 01:47 PM
magna's Avatar
magna
If its the same set up as the Nightrain, I find quite often after I fill up both the gauge and the little empty sign on the speedo both read empty but after a couple miles or so the tank gauge reads full and the speedo warning light goes out.
Old Jun 18, 2012 | 02:00 PM
colonelangus1's Avatar
colonelangus1
probably a sending unit issue its a job for the dealer under warrenty ..my gauge reads fine but low fuel light comes on at half a tank ..dealer is changing the sending unit on warrenty..im told its a common problem
Old Jun 18, 2012 | 07:05 PM
F22 Junky's Avatar
F22 Junky
ok, so not sure if this was the cause or what but when i relocated my plate i got the wires to the left signal/brake light backwards. when i swapped them back the fuel problem also went away. guess im just learnin what its like havein a harley lol.
Old Jun 19, 2012 | 02:04 PM
oct1949's Avatar
oct1949
That happens a lot in here on newbies,,
One second a problem...next second its gone...
glad it ok now anyway..
Phillipt
May 16, 2018 08:00 PM
cacasal
May 4, 2011 11:11 AM
Hangemhigh
Sep 18, 2009 10:09 AM
1200c
Jan 4, 2006 11:53 AM
radloser
Aug 27, 2005 10:20 PM
