dual disk on a Heritage softail classic
Old Jun 18, 2012 | 05:00 PM
Danofxdx's Avatar
Danofxdx
Default dual disk on a Heritage softail classic
Does anyone know of a setup for dual disks on a 2002 Heritage softail classic? my Girls bike is heavy and the brakes leave a lot to be desired, I'm used to my FXDXT with dual disk and I would like to see her bike have better brakes!
Old Jun 18, 2012 | 07:32 PM
KumaRide's Avatar
KumaRide
That is the a big negative with softails - not enough braking. A few have done dual disks. Not a cheap or easy mod. The forks are not setup for a second caliper. She will get used to it... Since the bike is 10 years old, make sure everything is working properly and the brake fluids have been changed as recommended - every two years.
http://www.adventureharley.com/softa...nance-schedule
Old Jun 19, 2012 | 06:01 AM
FastHarley's Avatar
FastHarley
Former Sponsor
Default Dual Calipers
This is a Heritage that was modified to work better. As all should know we do improved handling and no chrome/paint. This customer wanted 2" longer forks for added ground clearance as well as increased lean angle. HD tires suck so that rubber went out the window. A set of longer "Beer Cans" were added and the longer forks with dual caliper mounts were installed. A dual flange hub was installed and laced with polished SS spokes to a 17" hoop. I offer caliper adapters to adapt real Brembo calipers onto a pair of 320mm rotors. Not hard but buying real equipment costs money as does all high performance equipment. Here it is:
A close-up of the calipers on another project during mock up
Old Jun 19, 2012 | 06:43 AM
Danofxdx's Avatar
Danofxdx
Thank You for the info that setup looks great I will look into it, She loves her ride so all I can do is improve it
Old Jun 19, 2012 | 06:44 AM
Dooley's Avatar
Dooley
[/QUOTE]
This is the way they should come from the factory. Style should not take a back seat to safety.
Do you hear us MoCo?
Old Jun 19, 2012 | 01:01 PM
oct1949's Avatar
oct1949
I've said it before and I'll say it again, I can make my front tire sqeak easy,, anymore pressure I'd lock it up..
Don't know how much more I would want or need.
Those who are complaining maybe U need to check out the whole front brake system..
Lots of reasons they may not be working properly..
HDOakley
Wheels/Tires
Mar 9, 2024 06:20 PM
- Elliott
Nov 5, 2017 07:55 AM
inkpen00
Sep 4, 2014 04:05 PM
NCTURBOS
May 7, 2011 11:05 AM
amerseth
Jul 15, 2007 11:51 PM
