Shaking handlebars
Old Jan 11, 2007 | 09:55 PM
sklaber's Avatar
sklaber
Stage II
Default Shaking handlebars
Hello to all,
I have a 1997 Fatboy and at about 42 MPH the hanlebars have an erratic shake to them. Any ideas on what is going on?Tires and wheels have been balanced and still same thing. I am wondering if steer bearings may cause this problem, because I have noticed a light trace of grease coming from below post. It has not been over greased.
Thanks for your time and someone please give me a little advise where to start.
Old Jan 11, 2007 | 11:36 PM
flstfjeff's Avatar
flstfjeff
Default RE: Shaking handlebars
Better check those neck bearings,sound worn.Grease leaking out is a dead give away.
Old Jan 12, 2007 | 01:45 AM
cos's Avatar
cos
How many miles on your bike?
I adjusted a two metric scoots (cruiser and a standard)that did the exact same thing. I pulled the upper triple and retorqued the steering stem bearings and they're smooth as silk now.
Old Jan 12, 2007 | 09:56 AM
Mikey 1450's Avatar
Mikey 1450
Look at you front tire. Does it have any abnormal wear patters (cupped on outside edges)? if not, make sure your tire pressure is correct. Ifcontinues to shake, have someone else do aspeedbalance on your front wheel assy.If the balance is slightly off, it can cause this. I have never seen a head shake that wasn't caused by the front wheel / tire Assy.
Old Jan 12, 2007 | 10:25 AM
fmbeach's Avatar
fmbeach
Sklabar,
Had the same problem with my 97 Heritage. Had the fall-away (head bearings) adjusted to spec and no more head shake.
Tough job to do yourself and a pretty critical adjustment. Too loose and you get low and high speed head-shake to tight and you get handling problems. I would suggest you start with a good dose of grease to the neck, check for loose spokes, missing wheel weights and tire pressure. Nothing to fool around with.
Old Jan 12, 2007 | 01:29 PM
NW FXSTS's Avatar
NW FXSTS
ORIGINAL: flstfjeff
This topic has been covered here at length... Some grease leaks are ok dont need to freak people out.
m_mcdonnell314
May 2, 2015 11:31 AM
Bushy
Apr 11, 2014 09:40 AM
chevdude
Aug 2, 2011 11:12 PM
sledhead140
Jul 22, 2010 03:52 PM
Capt O
Jun 19, 2009 01:07 PM
