What size cables do i need?
Old Jan 9, 2007 | 01:34 PM
a72396's Avatar
a72396
Default What size cables do i need?
I need some serious help!!I have a 2004 Softail Standard and i just bought 16" apes. They measure: End Rise: 16.0”, Width: 39.5”, Center Width: 11.5”, Pullback: 11.5” and i want to buy Magnum sterling chromite II cables but i dont know what sizes i need, please help.
Old Jan 9, 2007 | 01:43 PM
chester1957's Avatar
chester1957
Default RE: What size cables do i need?
I can't be much help here, try this link, also you might contact who ever you are going to buy from for help. Good Luck.
http://www.magnumshielding.com/store/custom_length.php
Old Jan 9, 2007 | 01:48 PM
xxxflhrci's Avatar
xxxflhrci
Have someone hold the bars up to the riser tops, use a piece of rubber tubing to run the cable routes, then measure the lenght of each cable you need.
Old Jan 9, 2007 | 02:51 PM
stratplexi's Avatar
stratplexi
If you change the risers to 1.5", you are going to need 8" over on the clutch and 10" over on the rest.
Old Jan 9, 2007 | 03:26 PM
a72396's Avatar
a72396
What legnth for the front brake line do i need?
Old Jan 10, 2007 | 12:36 AM
stratplexi's Avatar
stratplexi
10" over your stock length on all cables except the clutch which will be 8"
The standard and FLSTC have the same stock cable lengths and I have researched this stuff to death. I am doing 16s on my Deluxe. You can find out your exact stock cable lengths by looking in the HD accessory catelogue. They are listed in the multi fit section. Let me know if this makes sense or if you need further clarification.
Old Jan 11, 2007 | 03:52 AM
a72396's Avatar
a72396
Stratplexi, So i have this right; for the front brake line i sould add 10" which brings me to 54" total legnth?
Old Jan 12, 2007 | 02:24 AM
stratplexi's Avatar
stratplexi
I am out of town right now and I don't have the HD catelogue to refer to so I am not sure on the total length. But...I know the cable has to be 10" over stock. I checked this recently and the Standard and FLSTC have the same stock cable length. Did you look in the accessory catelogue for stock length?
Old Jan 12, 2007 | 06:52 AM
lanceo70's Avatar
lanceo70
just put 16's on my 06 Standard last month. I went with Harley Stainless Steel cables, and went with 10" over stock on both, throttle and idle, and clutch...have fun!!
Old Jan 12, 2007 | 02:49 PM
a72396's Avatar
a72396
Do you have any pic's and how do you like the apes?
Springer110SE
Mar 27, 2013 05:08 AM
Mooseariss
Nov 15, 2011 08:55 PM
DR. V-TWIN
Sep 7, 2010 10:23 PM
dustinw58
Dec 1, 2007 09:18 PM
DDC1225
Sep 14, 2006 07:20 PM
Slideshow: Harley-Davidson's new RMCR concept revives the caf racer formula with modern hardware-and it may be exactly the reset the company needs.
