twin cam 88
Old Jun 25, 2012 | 02:00 PM
harley61s's Avatar
harley61s
Stage I
Default twin cam 88
rebilt uper end on my02 softy standard . now i have anoil leak out of he back mounting hol for the carb in the back jug. hve been told by the harley dealer that it's an o- ring in the oil pump . & friends have told me that there is a clog somewhere . COULD SOMONE PLZ HELP ME OUT !!!!!
Old Jun 25, 2012 | 06:47 PM
fcsallan's Avatar
fcsallan
I would say either is possible. The O ring at the top rear of the oil pump is easy to pinch during install and if it is pinched you would be pushing oil or it could have actually pinched and is partially blocking the port.
I would consider that it might be the Rocker box gasket put in upside down. It would then not block the breather passages and would allow the oil to build up in there. You call it, rocker box gasket set and pull the tank, or a cam cover gasket and exhaust seals. Either way you will be pulling something apart to take a look. Bummer man I just did a big bore on mine and would have hated to pull it back apart.
MudFlap379
Engine Mechanical Topics
Jun 18, 2014 06:25 PM
Deuce2004
Exhaust System Topics
Nov 2, 2010 05:16 PM
KumaRide
Dec 19, 2008 10:14 PM
Rosco230
Jul 12, 2008 02:56 PM
v8obs
Jun 22, 2007 10:25 AM
