SE204 cams do i need spacer kit?
Old Jun 26, 2012 | 02:12 PM
2003Custom1200's Avatar
2003Custom1200
Default SE204 cams do i need spacer kit?
Plan on ordering some SE204 cams this week for my '07 deuce. Seen in the SE catalog something about needed to order se spacer/shim kit for 07 newer softails? Is this needed or not? And any other helpful hints for install?
Old Jun 26, 2012 | 04:30 PM
QC's Avatar
QC
Prolly be a good idea. Take your time. read and re-read the manual and instructions. There are a couple videos on youtube about it- watch em. Take your time. I never did it before, took about 5 hours. Do you have all the o-rings and gasket? Good luck! Let us know how it turns out.
Old Jun 26, 2012 | 04:56 PM
TheTroupe's Avatar
TheTroupe
The short answer is yes. I had SE 204 cams installed this past winter and the PCIII dyno tuned, very nice.
Old Jun 26, 2012 | 05:37 PM
Freewheelin4eva's Avatar
Freewheelin4eva
lucky for me the fellow I ordered my 204 cams through gave me a set of spacers, let me use the one I needed, and gave the rest back. and I gave him my original one as well. worked good for me and saved a couple bucks.
Old Jun 26, 2012 | 07:33 PM
HoggyMtnBreakdown's Avatar
HoggyMtnBreakdown
Are you talking about the spacer that goes behind the cam sprocket? Best to measure for it once you have the new cams in place and then go get the one need. That's what I did when I did my cams last year. There are videos as well as some write-ups here on how to do that. Most notably the one by ATrain68 found here. There are like 5-6 available thicknesses, so it's best to know exactly which one you need, cuz those things ain't exactly cheap.
Old Jun 26, 2012 | 08:02 PM
jlasoftail's Avatar
jlasoftail
Yes, get it. It's worth making sure you have the right fit instead of just using the old spacer and only being close. When I just swapped my 255's for some 575 I was able to use the old one, but I did have some extras on hand...
Old Jun 29, 2012 | 09:04 PM
oct1949's Avatar
oct1949
found this...
http://www.harley-davidson.com/en_US...ts/-J04980.pdf
Might help Ya..????
J101
Engine Mechanical Topics
May 29, 2017 05:38 PM
mikelikesbikes
Mar 24, 2014 07:02 PM
2003Custom1200
Jul 2, 2012 07:06 PM
Mark g
Mar 31, 2009 03:06 PM
btfrom52
Mar 31, 2009 12:41 PM
