Progressive Drop In Question...
Old Aug 9, 2012 | 06:06 AM
fatboy1729's Avatar
fatboy1729
Question Progressive Drop In Question...
How difficult is it to install on a 06" Fat Boy? Any pics on the install or any advice is welcomed. Thanks...P.S. Riding a Shotgun in the rear...Thanks again...
Old Aug 9, 2012 | 06:54 AM
t34418l3-1's Avatar
t34418l3-1
its not hard at all, but you will need to pull the fork legs and then just cut the spacer to your desired length, pull the old springs out and put the new ones in, it quite simple, good luck
Old Aug 9, 2012 | 07:29 AM
Rok n Roll's Avatar
Rok n Roll
It is very simple, this is what i did
Old Aug 9, 2012 | 09:08 AM
beasleyiv's Avatar
beasleyiv
Very easy, just be careful when taking the cap off, those stock springs are under a lot of tension. I loosened them most of the way, then used a socket covered with a towel to finish them off. That way if the cap slipped out of my hand it wouldn't go shooting towards my face. Have had my forks apart more than I care to remember, this is by far the easiest mod.
Old Aug 9, 2012 | 11:34 PM
eric2011Deluxe's Avatar
eric2011Deluxe
Would it be the same procedure for a 2011 Deluxe?
Old Aug 10, 2012 | 08:53 AM
wadejesu's Avatar
wadejesu
If you leave the forks on the bike when doing the mod, make sure you have front end supported, once you loosen cap.bike will drop.
Old Aug 10, 2012 | 10:21 AM
Rok n Roll's Avatar
Rok n Roll
I have a 2004 Heritage, the Deluxe should be the same.
JekyllnHyde
Jun 19, 2019 02:26 PM
SmokeyJoe101
Mar 14, 2014 12:36 AM
Ironrodent
May 1, 2013 11:13 AM
JerseyDevil
Feb 19, 2011 06:35 PM
kylant
Jul 20, 2007 10:41 AM
