Dual Front Brakes?
Old Aug 10, 2012 | 10:43 AM
TXSailor's Avatar
TXSailor
Default Dual Front Brakes?
I'm looking to increase my stopping power on my '06 FLSTNI. It has a single disc up front.
I'm just reasearching options now but it appears they fall into the following "categories":
1) Replace the brake lines with SS
2) Replace the Caliper with something a bit more powerful
3) Add a Second Disc and Caliper
Anybody done an "upgrade" to the front brakes of these tyoes and what sort of results did you get?
thanks, D
Old Aug 10, 2012 | 11:07 AM
lionsqrne's Avatar
lionsqrne
A much cheaper alternative would be #2.
Either with a PM or a Hawg Halter. 6 piston. Hawg Halters can be found on ebay for around 375 dollars.
Old Aug 11, 2012 | 05:01 AM
oct1949's Avatar
oct1949
Number 2 has been done a lot,, few have done the double rotors..
read up on it and U'll see why and why not to do the double rotors.
https://www.google.com/search?source...=Google+Search
Old Aug 11, 2012 | 07:39 AM
bikerlaw's Avatar
bikerlaw
You can improve the braking of the stock system pretty significantly with a braided hose and a performance pad. Manufactures of pads such as Lyndall, Matrix, and EBC all make upgraded pads that shorten stopping distances, and a good braided hose gets rid of the soft lever Harley loves so much. Add a matching rotor and most people are pretty happy.
I don't think the new Harley calipers are all that bad in terms of function, they are just down right ugly. If I was to take the extra step and replace mine, it would be mostly for aesthetics at this point.
Old Aug 11, 2012 | 07:46 AM
fxdxrdr's Avatar
fxdxrdr
I added braided brake lines, performance pads, and floating disc rotors. The pads and the braid brake lines made a big difference with braking and feel. When my floating rotors wore out I put my stock rotors back on and didn't notice any difference in braking
Old Aug 11, 2012 | 10:35 AM
TXSailor's Avatar
TXSailor
Thanks for the feedback. New pads and braided line will be much cheaper than a new Caliper. They're pretty proud of those things! I'm leaning that direction as a first step and then if that does not satisfy me, then I can change out the Caliper.
I suspose I should do both front and rear but the factory calipers, pads and line on the back don't really seem to be an issue. I was on my Nephew's Kawasaki ZX-10R at the track last weekend, and WOW!!!! what a difference decent brakes make!!!!
I really liked the lack of "softness" in the lever. I roade a Classic Ultra in Las Vegas (duals) and it was just to "grabby" however.
Safe Riding, D
wombat457
EVO
68
Mar 25, 2020 08:45 PM
jmb79
Jul 30, 2014 04:18 AM
gdt3
May 24, 2011 09:22 AM
spaceblue
Dec 31, 2010 02:25 PM
Fla Glide
Dec 10, 2007 06:33 AM
