Cam Question...
Old Aug 12, 2012 | 09:07 AM
fatboy1729's Avatar
fatboy1729
Question Cam Question...
Hey forum, I hear alot of riders talking about changing out their cams for better performance. I have an 06" Fat Boy with the 88 engine. V & H short shots, PCIII, Screamin eagle a/c, stage 1. I just do not know what up grade cam I need and also, will it be real difficult to do yourself without expensive special tools? Pretty good with wrenching...Thanks for any in-put...
Old Aug 12, 2012 | 09:18 AM
cwsharp's Avatar
cwsharp
There are numerous threads on the forum that you can read and gain just as much, if not more (stuff that someone forgets) about choosing a cam than you will get as an answer this time. You would do yourself a favor to search the forum for "cams" and "choosing cams" plus visiting the Andrews and S&S web sites.
Old Aug 12, 2012 | 09:39 AM
ghoticov's Avatar
ghoticov
If you do your own wrenching, you can do it. I didn't install mine because I was afraid it might be too much but after doing other things, I believe I could have done it. As stated above, just do a forum search...there are many threads on it.
Old Aug 12, 2012 | 09:54 AM
magnum629c's Avatar
magnum629c
If this is all ur going to do to the bike I would run the Andrews 21....tons of low-end power. The labor is not that bad around 270$ . Pick the bike up and hold on!!!!
Old Aug 12, 2012 | 10:00 AM
magnum629c's Avatar
magnum629c
The Andrews 21 and 26 are great cams for ur setup but if u have plans for more moterror work down the road there's better choices
decencyxdefied
Apr 17, 2015 07:15 AM
fatboy1729
May 15, 2012 10:23 AM
buzzpowerz
Mar 21, 2010 04:31 PM
4merRacer
Oct 18, 2007 01:31 AM
lionsqrne
Apr 19, 2007 12:37 AM
