Nostalgia is Dead
Old Aug 10, 2012 | 07:11 PM
Tlman66's Avatar
Tlman66
3rd Gear
Default Nostalgia is Dead
I have a problem with my 1993 FLSTN. It cut off w/o warning the other day, but after sitting for about a minute, it re-started and I was able to ride it home. I noticed, however, the neither the Tach not the signal lights were working, although the headlights and passing lamps were lit. Once I got home, it died again.
When I jump start the bike and put a meter on the battery terminals I can watch the voltage dropping.
The battery showed only about 9 volts. I did an AC Voltage test and resistance test on the stator. Both were normal. I have no resistance across the main breaker.
Normally I would change the regulator, but I have never heard of a bad regulator affecting the signals or Tach.
Anybody deal with this before, or have any ideas?
Thanks
Old Aug 10, 2012 | 07:40 PM
RANGER73's Avatar
RANGER73
Could be a bad battery.
Old Aug 10, 2012 | 07:53 PM
Tlman66's Avatar
Tlman66
3rd Gear
Thanks, might be, but when I put trickle charger on it, it appears to be taking the charge. I also checked the cables, and they're tight at both ends. The battery is a Harley battery, and is less than 6 months old.
Old Aug 10, 2012 | 07:58 PM
decencyxdefied's Avatar
decencyxdefied
warranty that thing lol
Old Aug 11, 2012 | 03:50 PM
RANGER73's Avatar
RANGER73
Batteries go bad, could be a bad cell.
Old Aug 11, 2012 | 08:28 PM
cjbmustang's Avatar
cjbmustang
corrosion on the terminals perhaps? i'm not too familiar with motorcycle charging systems, but if i remove the battery on my car, the alternator will keep the car running.
curious to know what it is!
Old Aug 12, 2012 | 10:00 AM
RANGER73's Avatar
RANGER73
Not if you have your lights and other stuff on.
flhtc04
18
Apr 3, 2014 04:28 PM
mkelley7
Jun 19, 2013 03:13 PM
Tlman66
Aug 10, 2012 08:51 PM
andyp
Sep 12, 2010 10:52 AM
hucks 08
May 26, 2010 07:23 PM
