Not another Cam question!
Thanks, Pete
DD Fatcat for FLSTC is nice as its longer then the other DD pipes for softails and gives a sleeker look to the bike kinda like your pipes. Check this out:https://www.hdforums.com/forum/4453612-post10.html
Look at some of the dyno's of the longs and U'll see why.
I'll put in sheets of 2 of my Sons bikes that he used to own with 2 different V&H's pipes that are exactly the same (cams, AC, Sert, dyno at the same place by same tuner) other than the pipes, The sheets will show U the diff the pipes can make.
Sons 09 NT with 204's and BSL's
Sons 07 Duece with same 204's cam and BR's 2-2s
Also notice that the TQ and HP numbers is not the same on both sides of the t sheet,, have to come in from the right side of the page to see TQ numbers..
And just for the heck of it I even put in my Cam only 96'er with stock header and Rush slip-on that I installed Andrew 26's which is close to the SE 203's.
As U see even with the stock headers mine makes 83 # of TQ above 2250 rpms.
That's why IMO U'll should see a Big difference in the 2000 -3000 rpms just with a pipe change.. instead of cams.
point is the BSL's make 70# TQ at 2500rpms.
And the BR's 2-2 made right at 87# of TQ at 2500 rpms..
U wont find any (cams only) istall that will make up that.
