keep blowing signal light bulb
Old Aug 23, 2012 | 06:32 PM
checkers's Avatar
checkers
Originally Posted by jlasoftail
OK, I have to ask... Rear fender tip assembly to fix front signals/markers?
PM sent
Old Aug 23, 2012 | 06:45 PM
Jackie Paper's Avatar
Jackie Paper
I assume you are using a Harley motorcycle bulb. Aftermarket AutoZone/Walmart does not have the anti vibration built into it. The first one probably was defective and had a short life.
Old Aug 23, 2012 | 07:21 PM
jlasoftail's Avatar
jlasoftail
Originally Posted by checkers
PM sent
Funny, I'll admit your idea made no sense to me, but I checked and sure enough that bulb was burnt out too, probably for a long time. With the chrome cover you can hardly see the light unless you're behind the bike in the dark. Anyways, I checked it out, pulled it off the bike, cleaned up the connections, checked for shorts and done some voltage tests and all seems good. Replaced bulb and hope for the best. Thanks guys.
Old Aug 28, 2012 | 06:24 PM
checkers's Avatar
checkers
Your welcome!
Old Aug 28, 2012 | 07:14 PM
Branner's Avatar
Branner
Originally Posted by PanHeadRich
I was frequently changing front signal bulbs on my 97 (never the rear). I never understood why the left burned out more often than the right. But I was replacing one or the other every week or two. Spring of 2011 I went with all LEDs and haven't had a single issue since then. I went with the higher quality LEDs from Custom Dynamics. They're extremely bright and have a lifetime warranty ... but of course they're not cheap.
Same here, Rich. I put LED's in and haven't had a problem since.
emerican19
Jan 28, 2015 04:03 PM
Gary86
Jun 21, 2011 05:03 AM
trikerbob2
Oct 17, 2009 01:17 PM
DosDiablos
Electrical/Lighting/Alarm
Jul 18, 2009 07:55 PM
lewlew
Aug 14, 2008 08:36 AM
