I have a 2008 Softail Standard with profile (smooth) rims. I suffered a massive failure in the rear wheel bearings which chewed out the rear hub and as a result I need to replace the rear hub.
Harley does not sell a replacement hub but I believe that V-Twin Mfg makes one to suit.
Has anyone used one of these hubs to replace the original one? If so, is it any good? Do you know the correct part number and can you recommend a shop to source one from?
