wire/cable length with Wild One 501s
Thanks!
I used the stock cables and wires, but the wires were very close to being short. Now I didn't move the harness forward from the connector under the tank, so I don't know if there is any slack back by the battery.
If you are going to internal wire them, and have not done this before, you are in for a real lesson. Lube the harness up good and use mechanics wire to pull them through, I tryed string the first 2 times, but it kept breaking. Wrap the bars with cloth or something to protect them while you are fighting with them. LOL
. Get some good grips and install the throttle side side first, so you can match the "pattern" or "Rotation" on the clutch side when you glue it on.
Have fun and be patiant.
[IMG]local://upfiles/1358/2DDDD336DCC246E9A24604BD4E98D127.jpg[/IMG]
[IMG]local://upfiles/1358/FACB252CEE2A40F0988F842A17FC5E51.jpg[/IMG]
Thanks again!
Scott
