Rear fender light question.
Old Sep 12, 2012 | 10:14 PM
bikerlaw's Avatar
bikerlaw
Default Rear fender light question.
I was messing with the tail light on my '05 Fat Boy and I noticed there is a junction block behind the light that everything plugs in to. I see one plug is empty. Is that unused plug where a person would plug a fender light into? If so, I'm pretty sure I have found something I want to install. After all, lots of light in the a$$ end of a motorcycle is always a good thing. At least IMHO it it. So my question is this..... what year fender tip light will plug into that receptacle? Does it have to be from a Softail, or can I use one from a touring bike? If so, what years. The research I have done this far shows any light from a 2000-2008 touring bike will plug in, and all I would need to do is drill 2 holes in the fender to mount it. Does this sound correct? Please give me some input so I can order the right part. Its probably pointless to even go to a dealer since those retards will just say Fat Boys don't have rear fender lights so we can't get you one. Please advise.
Old Sep 13, 2012 | 08:14 PM
bikerlaw's Avatar
bikerlaw
So come on guys. Your gonna leave me hangin' here? With all the Softail experts on this forum, no one knows if a touring light will work on a Softail?
Old Sep 14, 2012 | 09:27 AM
LaidInk's Avatar
LaidInk
I'd think if fender measurements match it would work. As for the plug a test light or multi meter would be your best bet to see if it has power if not, a simple splice into the running light wire would work.
Old Sep 14, 2012 | 12:41 PM
Benway's Avatar
Benway
I can grab a good close pic of mine if you need...
Old Sep 14, 2012 | 12:48 PM
soft 02's Avatar
soft 02
It might be a universal part that they also use on the touring bikes then it would have a different function for that line but I could be talking out my *** again?
Old Sep 14, 2012 | 04:25 PM
bikerlaw's Avatar
bikerlaw
Thanks guys. Yes, the empty receptacle does in fact have power when the key is turned on. My concern is whether the 2000-2008 touring light will plug into that Softail junction block. If it will, then its a simple plug and play. If not, then I have to find the right plug or start soldering wires. Which is fine, but I would prefer the easy way if possible. I am already drilling holes in the fender to mount the light, so if I can get one with the correct plug I would rather just avoid the hassle.
Benway, a pic would be great. The light part numbers all seemed to switch in 2009, so if it fits yours, I suspect it will fit and plug into my '05.
dynamedic
Feb 1, 2019 06:38 PM
bedrock1
Jun 6, 2017 06:07 AM
marke489
Electrical/Lighting/Alarm
May 4, 2017 07:04 PM
oakspeed
2014-2024 Touring Models
Oct 29, 2014 04:46 PM
Joe12RK
Jul 13, 2012 11:28 AM
