Engine shut down after tight turn ?
Old Sep 16, 2012 | 10:47 PM
Pathfinder1's Avatar
Pathfinder1
6th Gear
Arrow Engine shut down after tight turn ?
I have a 2005 Heritage classic ,, Changed my oil and went out for a run out in the country with the wife , and after about 15 miles of put - putting around looking at houses i lugged into a Very tight 10 mph right turn doing about 5mph and as i came out of it hit a gear the engine shut down with oil light on ... I freaked !!! I looked down on the road to see if i had a puddle and seen nothing. I then checked the oil which as good then i turned to engine over and it stated up ,,So i shut it off ....I then made a few calls and was told there is a low oil sensor that on some tight turns can shut your machine down . My question is is this true? i road the bike home just fine and dandy but still made me nervous. Thanks,,,Bob
Old Sep 16, 2012 | 10:57 PM
Rakthi's Avatar
Rakthi
As far as I know there is no such sensor on the bike.
There is a bank sensor that will shut the bike down when you drop it. But don't think that you were leaning that far over.
You probably just stalled the engine ... 2 up in a corner at 5 mph ... too high a gear coming out ... easy to stall engine. When engine stops, oil light comes on. ...
Old Sep 16, 2012 | 11:06 PM
Pathfinder1
6th Gear
Default re
Thanks,, thats what it sounds like what happened ...My 1st thought was a seized engine ! ,,,with wife with me it didnt help matters !
Old Sep 17, 2012 | 08:00 AM
hspring03's Avatar
hspring03
Is it also possible that in that tight right turn, your right hand moved enough to hit the run button off?
JaboIam
Jul 8, 2018 01:28 PM
danjab
Engine Mechanical Topics
Jun 11, 2017 12:42 PM
spizzyman
Jun 27, 2010 07:50 PM
PPBART
Aug 14, 2009 12:54 PM
cglofland
Apr 30, 2008 07:26 PM
