Softail Wide Tire
Old Sep 24, 2012 | 09:05 PM
ronjon8505's Avatar
ronjon8505
3rd Gear
Default Softail Wide Tire
I have a 1995 FLSTC and put a new tire on the back...unfortunately it is about 1" wider! Its a D402 instead of the stock D401, perhaps?? Anyway...no matter what model tire it is...so of course now it rubs against the belt. Is it safe to put a 1/4" spacer behind the sprocket to kick the belt out just a tad? Looking up from the *** end down the belt to the primary sprocket, I can see that there is at least 1/4" of gear teeth to the outside, allowing for the posibility of the belt to shift out away from the tire. Is this a typical fix, is it safe, or should I just fess up and get the right tire size?
Old Sep 24, 2012 | 09:17 PM
Benway's Avatar
Benway
Have you looked into the skinnier belt and pulley a newer Fatboy has? (just a guess)
Old Sep 24, 2012 | 10:44 PM
langwilliams's Avatar
langwilliams
Look at where the belt is riding on the front pulley.the front is a lot wider than the rear an the rear determines belt tracking. If there's room on the front pulley you can no problem. I have one out in my garage right now if interested.
HardLuck71
Apr 3, 2018 07:03 PM
JesseDyna
EVO
13
Mar 13, 2018 04:28 PM
MDER123
Oct 29, 2010 08:31 AM
sewerat
Apr 10, 2008 08:29 PM
rkc9999
Feb 27, 2007 11:45 AM
