drive belt question
Old Oct 26, 2010 | 05:49 PM
MDER123's Avatar
MDER123
Default drive belt question
Hey friends......
I was going over my bike and I looked at the rear tire on the drive belt it looked worn or almost looked like the belt was rubbing on the tire. Any Ideas??
Old Oct 26, 2010 | 06:12 PM
bigmikaele's Avatar
bigmikaele
you looked at the rear tire on the drive belt? Not sure I follow, but just your comments about the belt. What size tire are you running? How old is the current belt? Who replaced your last tire? Did they align the rear tire properly? If in fact it is worn/frayed you will need to replace it pretty soon.
Old Oct 26, 2010 | 10:22 PM
Fixintu's Avatar
Fixintu
Originally Posted by MDER123
Hey friends......
Yes, put the bottle down.
Old Oct 26, 2010 | 11:36 PM
goblin127's Avatar
goblin127
Sounds kind of odd.
Old Oct 27, 2010 | 01:51 AM
sbyumabaker's Avatar
sbyumabaker
Make sure your tire is properly lined up, if tire is the OEM recommended size you might just need to make sure both sides of wheel are at the same distance in relationship to each side of rear axle……. Hope it’s that simple… Good luck
Old Oct 27, 2010 | 01:33 PM
MDER123's Avatar
MDER123
You are all to funny!!!! It looks like it rubbed on the tire... I am running stock tires. But thank you for the chuckle and advice.
Old Oct 27, 2010 | 01:35 PM
Mike T's Avatar
Mike T
When that belt breaks,won't be funny then.
Old Oct 28, 2010 | 04:13 AM
MDER123's Avatar
MDER123
The belt is not frayed.. Nor splitting or cracked. And does not even look damaged. I was laughing about the "put the bottle down" comment
Old Oct 28, 2010 | 07:31 AM
dyna rider's Avatar
dyna rider
Default Drive Belt
You need to get a manual and do an axle alignment...Stock tire is a 150 ? Shouldn't be rubbin'.
Old Oct 29, 2010 | 06:45 AM
grbrown's Avatar
grbrown
Red face
There is or should be a belt guard that fits between the belt and tyre. With the guard off the gap between belt and tyre is plenty. If your tyre really is touching the belt either rear wheel alignment is very bad and/or vehicle alignment is way out. Either way read your service manual, check and adjust!
