questions for lowering 06 night train
Old Sep 28, 2012 | 08:24 PM
Nancy Mcmanus's Avatar
Nancy Mcmanus
Stage II
Default questions for lowering 06 night train
just had my bike lowered using bolt kit and now i'm hearing a whistle or flapping noise when giving it gas, on the left side from the motor. should any belts have been adjusted to not cause undue pressure anywhere? would the re-balancing of the bike level cause something to need to be adjusted?
Old Sep 28, 2012 | 08:35 PM
jreichart's Avatar
jreichart
Belt might be rubbing. Mine rubs the top of the opening in the primary. Doesn't make any noise though. Look closely at the belt, and the belt guards if you still have em. Belt tension shouldn't be that far off, the swingarm is designed to move through its range without tightening or loosening the belt much from spec.
Check your tire too, make sure it's not being rubbed by the fender bolts.
Old Sep 28, 2012 | 08:40 PM
Nancy Mcmanus
Stage II
understand what you're saying. checked all what you suggested. so to your knowledge there aren't adjustments to the belts that should be made when lowering? the noise is 100% coming from the v twin area when i give it gas
Old Sep 28, 2012 | 09:17 PM
jreichart's Avatar
jreichart
The belt should deflect about 1/2" with 10 lbs pressure about 1/2 way between the pulleys, IIRC. Check that, and check the tracking. Put it up on a lift in N, and spin the rear wheel forward and backward. Belt shouldn't move laterally in the pulley at all. If it does, adjust the alignment using the adjusters on the axle. If there are no rubs or alignment issues, don't know what could be making the noise. Lowering the bike shouldn't affect anything with the engine. Could be something unrelated that happened to coincide with the drop. Maybe someone else will chime in with some ideas.
Old Sep 29, 2012 | 03:58 PM
jreichart's Avatar
jreichart
I'll bump it for ya, see if you can get some more input...
Old Sep 29, 2012 | 07:01 PM
Ash16's Avatar
Ash16
Mine was the belt slapping on the belt guard. I took the guard off and now I can hear my belt squealing . So now I'm rubbing the belt with bar soap until I have a chance to adjust it.
Harlay Hawk
May 2, 2021 09:14 AM
smketr7139
Sep 26, 2012 09:53 AM
FDHOG
Mar 27, 2012 10:42 PM
bpope
Feb 5, 2012 07:55 PM
JohnnyBoy
Apr 7, 2008 02:34 PM
