Carb problem
Old Jan 26, 2007 | 01:29 PM
jimvlv's Avatar
jimvlv
Stage III
Default Carb problem
Bike idles fine, I can get through the gears at a normal pace, but any attempt to rapidly accelerate results in the motor sputtering. Any suggestions? Thanks 93fxstc
Old Jan 26, 2007 | 02:44 PM
Babs's Avatar
Babs
Default RE: Carb problem
Two other factors there.. Type of exhaust setup and air cleaner setup.
Same here if I'm in low RPM's and give it the throttle, I might have it spit a little.. I attribute it to a torque dip in the low-mid RPM range.. Which is attributed to running drag pipes.. Though this is much much better with the rineharts on my bike than the bigshot shorts I used to run, it's still present. I wondered if it was possibly due to jetting. Hard to say.. I'm no tuner.
I can say though your exhaust will have a huge affect on this.. I simply added some backpressure by going with a more restrictive bub "quiet" baffle rather than the very free-flowing stock Rinehart baffle, and that torque dip was virtually eliminated.. No issues with any low-RPM accelaration.. But it sounded like crap. So my take on this is the increased backflow pressure made the difference. Makes me want to just raise the profile in the stock baffle louvres just a wee bit to see what happens.. Just to dial it in just right, maybe.
Old Jan 29, 2007 | 01:11 PM
twowheelsforever's Avatar
twowheelsforever
Can you provide any more info on what setup you have for air filter and exhaust? Have you made any changes recently before this problem started?
Little Mike
Nov 7, 2016 10:55 AM
bikerlaw
Exhaust System Topics
Jun 8, 2010 06:28 PM
stroker23
Shovelhead
Jun 1, 2008 08:54 AM
Doug45601
Feb 3, 2008 12:48 PM
DARRTILLM
Oct 7, 2005 06:36 PM
