Speedo cable tip stuck in wheel mount sensor
Old Nov 7, 2012 | 01:08 PM
Wakko47's Avatar
Wakko47
Default Speedo cable tip stuck in wheel mount sensor
The speedo cable on my '95 Heritage tore itself to pieces but left the square tip in the sensor mounted to the front wheel. I'd like to get it out so that I can install the new cable today and not have to order a new part, but so far no joy. Any ideas? I tried a #4 sheet metal screw but it's too big to screw down into the remnant to yank out. So far I can't find skinny enough needle nose to reach inside the tube either. :/
Old Nov 7, 2012 | 05:17 PM
FroggyFatBoy's Avatar
FroggyFatBoy
do ya have any pointy seal picks ? if so try using them on opposite sides of the broken piece and pull or pry it out. no seal picks ? try to use paperclips straightened out and grind the ends to a point. hopefully the cable didn't get to hot and seize itself in the drive.
Sissy24
Shovelhead
Sep 2, 2014 06:04 PM
redhead356
Ironhead
Nov 7, 2012 04:31 PM
85RoadsterXLS
May 23, 2012 07:46 PM
88 xl12 Sporty
Aug 25, 2009 08:32 PM
quigley
Mar 25, 2007 09:39 PM
