How did you remove the wiring on headlamp shell to put the chrome cover on, the wiring for the headlamp goes thru the hole on cover..
Gotta pull the pins from the connector. Takes patience.
The one thing I could not figure out (without removing the tank) was how to get the fender light off to remove the fender. So I removed one fork first while leaving the fender attached to the other side and then removed the fender and set it on a milk crate and covering it with a towel. Then removed the other fork. Leaving the wiring to the fender intact. Then just put it back together the same way I took it apart.
