Deluxe wont start?
Old Nov 19, 2012 | 09:57 PM
VWNESTA's Avatar
VWNESTA
Default Deluxe wont start?
Well I went to start my 2012 Deluxe while in nuetral and I push the button and nothing...
The lights are nice and bright and I hear the fuel injection kick on but not a sound from starter or anything, no crank what so ever.
Volt meter says that I have 12.7 volts on battery, I put a batter charger on it anyway for a couple of hours and charger reads "full charge"
Tried working the clutch, tapped on starter, rocked back and forth in gear.
Just looking for ideas to try from you all. I know its under warranty but dealer is located 4 hours away and no indy. Thought I would ask for ideas before I try to get it to the dealer.
Thanks, much appreciated
V/r,
Mike
Old Nov 19, 2012 | 10:08 PM
VWNESTA's Avatar
VWNESTA
Oh and was just riding it last night and no indications of problems, got home last night, shut her down and today... nothing
Old Nov 19, 2012 | 10:21 PM
Fhatboy's Avatar
Fhatboy
Check the ground on the battery before you get too far into other things. had the same thing happen 3 years ago.
Old Nov 19, 2012 | 10:22 PM
Vic Bronco's Avatar
Vic Bronco
Maybe check to see if your ground wire is a bit loose where it bolts on the frame, happened to me once.
Other thing may be that if you have the factory security the battery in your fob may be dead, but you would have noticed your turn signals flashing when you tried to start the bike.
Old Nov 19, 2012 | 10:29 PM
studbolt's Avatar
studbolt
+1 on the FOB battery, had similar problem on another bike I had. Changed the battery and it fired right up.
Old Nov 19, 2012 | 10:39 PM
VWNESTA's Avatar
VWNESTA
thanks guys, no key fob or security system, sorry forgot to say also I cleaned all battery terminal conections and ground connections as one of the first things I did.
Guess I'll go get the battery load tested tomorrow, possibly fuses? Not sure where they are located.
Bike only has 1200 miles on it.
Old Nov 19, 2012 | 10:50 PM
wfojon's Avatar
wfojon
Is the handle bar switch in run?
Old Nov 19, 2012 | 10:52 PM
jjames's Avatar
jjames
Not to insult you or anything but is the kill switch on the bars in the run position...I don't use mine but I've seen it happen more than once. I prefer it to be something stupid I'm doing where I can just call myself an idiot than something that requires time and money to fix.
Old Nov 19, 2012 | 11:06 PM
VWNESTA's Avatar
VWNESTA
Lol no worries, yep in run position, even took it apart to make sure it wasnt corroded up and it looked nice and clean.
Old Nov 20, 2012 | 12:28 AM
SanJuanRon's Avatar
SanJuanRon
It sounds like the FOB battery if it's a '12 and you checked the other obvious areas. SJ Ron
