Question on fender struts between years.
Old Nov 21, 2012 | 06:35 PM
theyammieguy's Avatar
theyammieguy
Default Question on fender struts between years.
What's up? I have a 94 softail springer. Gonna put a klockwerks stretched rear fender on it. I have a question about the fender struts. Have the mounting holes changed throughout the years? Klockwerks has two fenders for the softail. One is not pre drilled and one is pre drilled for 2000 and up softails. If I bought the pre drilled fender, would the holes line up with my struts? Are the strut to frame holes the same distance apart? I could just buy new struts if they'll bolt to my frame.
Old Nov 22, 2012 | 06:11 PM
theyammieguy
Bump.
Old Nov 22, 2012 | 08:02 PM
back again's Avatar
back again
buy the solid one and do it your self. A lot more mounting choices when you go that route.
Old Nov 22, 2012 | 08:15 PM
theyammieguy
Yeah, I think you're right. I'm actually surprised there aren't more stretched fenders out there for the softails.
Old Nov 22, 2012 | 08:51 PM
shineybike's Avatar
shineybike
I'm not sure about the hole locations, but I think the tire width increased some time in there and that might determine which will fit. Wider tire...wider fender....different strut covers.
Old Nov 22, 2012 | 09:09 PM
OkieNiteTrain's Avatar
OkieNiteTrain
Back Again is right. Buy the undrilled. I filled the holes in on my Fat boy fender and re-drilled them to set closer to the tire. Nobody has ever asked about it so I guess it is not apparent that my rear fender gives it half of the lowered look. Lot of things can be done by buying undrilled metal for these sleds. Worth just what I charged you for it.
Chopper Nate
General Topics/Tech Tips
Oct 4, 2014 02:15 AM
hdmike1969
Mar 13, 2013 05:46 PM
mphillips
Sep 26, 2010 09:59 AM
besibela
Shovelhead
Apr 1, 2010 02:56 PM
FirstRealBike
Sep 2, 2008 12:33 AM
