Advice
Old Dec 2, 2012 | 07:47 PM
BARN36's Avatar
BARN36
Default Advice
Any recommendations on how to take the reflectors off my slim?
Old Dec 2, 2012 | 07:52 PM
Cousy's Avatar
Cousy
Assume you're talking about on the forks. I just pulled mine off by hand and got the residue off with a product called "goo gone" I think. Heating them up first may pull off more of the residue with the reflector.
Old Dec 2, 2012 | 08:01 PM
Vic Bronco's Avatar
Vic Bronco
I've always just pulled them off, they are stuck on with 3M double sided tape. I know some people have used dental floss, but I didn't have a problem just pulling them off by hand. I can't remember what I used to remove the residue from the tape, but for some reason I think it was rubbing alcohol and a shop rag with a bit of elbow grease to get it all off.
Old Dec 2, 2012 | 08:44 PM
RDK09's Avatar
RDK09
I've heard of guys usin fishing line and goo gone.
Old Dec 2, 2012 | 08:48 PM
Smileman's Avatar
Smileman
Leave them on and live longer
Old Dec 2, 2012 | 08:52 PM
Ridin on the darkside's Avatar
Thats what i did,WD40 works also
Old Dec 2, 2012 | 10:13 PM
Bone Doc's Avatar
Bone Doc
I tried heating them with an Industrial heat gun and it probably helped but, all in all, not that much. I tried dental floss after heating but the floss kept breaking. I didn't try fishing line.
I ended up just pulling them off and using a thin piece of plastic to remove as much of the thicker residue as I could. I then kept soaking the remaining residue with Goo Gone and used the plastic to remove the rest. It probably took 5-10 minutes per reflector.
Goo Gone will not effect the metal finish, even chrome. I used it on the aluminum lower fork reflectors and the reflectors on the chrome sissy bar sideplates.
Old Dec 3, 2012 | 05:22 AM
acman308's Avatar
acman308
I used heat gun then then fishing line.
WD 40 to clean of residue
Old Dec 3, 2012 | 05:39 AM
jreichart's Avatar
jreichart
Now that's just crazy talk....
Old Dec 3, 2012 | 06:41 AM
Green Hornet's Avatar
Green Hornet
fishing line and goo gone worked well for me.
