Increased Vibration After Compensator Replacement
I was having problems starting my 2008 Heritage Classic after it was warmed up so I took it to the dealer. They diagnosed the issue as a bad compensator sprocket. ESP covered the costs minus deductible, which was nice, and my startup issues are now gone. However, I am noticing a significant increase in vibration on my footboards and highway pegs than was present before the compensator replacement. The dealer told me that the normal replacement now is a SE version. Should I notice a significant increase in vibration?
Thanks all!!!
It can cause the stator go bad causing starting issues.
Most I remember with the comp was the Clunk on start up or Rattling in the motor on acceleration (usually loose comp nut) in the 07's-08's and 09's with the 07's the worse.
It seems like I remember that in 07 when some in here were replacing them they were not a simple bolt in change out.. There was something that had to be done for the SE comp to work right.
Seen like they (member were cuting grooves and slots to improve the hub lubercation, U' need to do some researching to find out what the deal was.
Here's another members post about the SE comp. from this thread https://www.hdforums.com/forum/touri...ch-better.html
10-31-2012, 10:04 PM
btsom
Senior Rider
Garage is empty, add now
I hope you get the best deal possible. Part of the price of the change is a new rotor, the old one is not compatible with the new comp assembly. The comp and spring pack may be about what was quoted above, but the new rotor adds a bit to the overall cost.
I have around 32,000 miles on my SE comp. It got noisy when I tried ATF in the primary but quieted down again with 20-50 back in the primary. I have done the grooves and slots modifications to improve hub and cam face lubrication and will assume that has done the trick until it gets noisy again.
My stock comp (08 Road King) made the engine start bang from day one. Didn't know what it was for almost 2 years. Nearing 15,000 miles the primary got so noisy and rough I couldn't stand it any more. Naturally, was told "they all do that" so I installed the SE comp myself. Have never been sorry, it was a great improvement and I continue to be well pleased.
here's a write up on it.
https://www.hdforums.com/forum/touri...it-w-pics.html
The symptoms I was having when I took the bike in to the dealer was that once the engine was warmed up to normal operating temp and I shut it off, when I tried to restart it there would be clanging and it would sound like my starter gears were going to be sheared off and it would also blow back out the air cleaner. After the compensator replacement the problem went away completely. ESP covered the work so I only had a $50 deductable.
Related or not, other things that I had asked the dealer about also went away after the repair. One of those things was what sounded like something loose in the valve train on the front cylinder, engine ping when it shouldn't have, loss of torque pulling hills and shudder when taking off from a stop. All those things I was told was normal but didn't appear until I hit about 20k miles, and all are now gone. Mystery for sure! My bike runs better now than it has for the last 10k miles.
Also, after riding the bike for about 400 miles over the weekend it appears the vibration has lessened back to pre-compensator replacement. When I first got the bike back the vibration when riding up a hill (as in Texas Hill Country, not something serious) would vibrate my feet off the footboards and caused thigh pain if feet were on the highway pegs. Now it is a ton better.
Nevertheless, I am still going to call the dealer this afternoon.
The 07's and 08's have the loud clunk on start up.. and Yes the SE comp usually fixes that..
It was last yr or this yr the SE comp is standard on all the 103's,
Ur viberation issue is Weird.. I'll say my 07 has been smooth since day one,, I don't even get a Buzz some say they have ,, Like the mirrors distorts their image at speeds. Mine doesn't do that either..
another thing is if Ur shoes rest's on the floorboard rather than just the Inserts U'll feel more vibs. Those rubber **** on the Inserts are made to absorb the vibs..
Glad to help most issues worked out for Ya..
