02 FXST key starter switch conversion HELP.
Old Dec 18, 2012 | 06:11 PM
shreddy cougar's Avatar
shreddy cougar
4th Gear
Default 02 FXST key starter switch conversion HELP.
So I decided to swap from 16" apes to moto bars. I didn't like the way the hand controls looked so I decided to put an internal throttle and a key switch where the horn was. So I got rid of the horn, and turn signal buttons. Also got a toggle switch for my hi low beams which I have not installed. The starter switch has 4 poles G, which I'm guessing might be ground, ST, which should be starter I wired that to my starter relay, AC, for accessories Im guessing so I wired that the same as my run button going to my spark plugs (black and white wire) and B, which I'm guessing is for battery that I wired to my ignition (Grey)
I tested it out and no go. Any suggestions, Kinda bummed out on it. I don't have the fuel hooked up because I just wanted to see if the circuit worked before I shrink wrap it all up.
BlackDenim&Chrome
Apr 2, 2025 07:30 AM
Conroy Pete Smith
Electrical/Lighting/Alarm
Apr 24, 2016 09:21 PM
Freewheelin Franklin
General Topics/Tech Tips
Aug 19, 2012 04:11 PM
bensoniq
Jun 18, 2010 06:52 AM
sutphen30
Ironhead
Jun 11, 2008 06:33 PM
