GripAce or Alternative?
Old Dec 22, 2012 | 06:20 PM
SwiftyBKells's Avatar
SwiftyBKells
Default GripAce or Alternative?
I've been searching the site & googling but haven't really came up with anything solid.
Has anyone used GripAce but not install the switches in their grips? I was thinking of getting this but hiding the switches somehow. Is there an alternative to GripAce? With either option, can you post pics/how to?
Old Dec 23, 2012 | 04:32 AM
Deadanimal's Avatar
Deadanimal
Here is what you can do with the grip ace if you don't want to put in grip. If you use twist clutch you can't put in grip anyway.
You can put the switch pad anywhere you want or you can use micro switches. But only on pre 2011 bikes without the CANBUS wiring.
Old Dec 23, 2012 | 08:44 AM
Branner's Avatar
Branner
I put my grip ace under my gas tank.
Old Dec 23, 2012 | 08:51 AM
Hogpro's Avatar
Hogpro
Former Sponsor
Mine is on the left grip. I put the module under the fork tins.
Old Dec 23, 2012 | 09:55 AM
jreichart's Avatar
jreichart
Grip ace will send you a machining diagram with the button pad. You can recess mount it anywhere you can machine the recess. I might still have my diagram laying around if you'd like me to post it up. Not so sure about surface mounting, the button pad is not enclosed on all sides, the bottom is exposed circuit board, so it might be ok in a hidden location.
I can say it's a great setup, one full season on mine and no hiccups or problems at all.
semiret
Jul 23, 2014 07:32 AM
pomeara
Feb 1, 2014 09:03 AM
dallen
Jul 24, 2012 09:17 PM
grunt999
Feb 28, 2008 12:01 PM
Axeman71
Aug 11, 2007 09:07 AM
