shifter shaft seal ?
Old Dec 28, 2012 | 06:35 PM
bobbyjoes's Avatar
bobbyjoes
Default shifter shaft seal ?
If you had a shifter shaft seal bad it wouldnt be primary fluid would it it would be tranny correct ,i have 2 seperate oils not same ,thanks
Old Dec 28, 2012 | 06:41 PM
Jackie Paper's Avatar
Jackie Paper
shifter shaft = transmission. leak coming from primary inner primary shaft bearing seal would run into same area
Old Dec 28, 2012 | 06:44 PM
bobbyjoes's Avatar
bobbyjoes
ok,thanks ,guess i got a project to do this winter ,harley is in the dinning room so keep warm anyways,thanks
Old Dec 28, 2012 | 07:06 PM
kkiley's Avatar
kkiley
Change all the primary case seals while you have it apart. Make sure to get the new style starter shaft seal. It has a small spring around the lip on both sides of the seal. The old style only has it on 1.
Old Dec 28, 2012 | 07:12 PM
bobbyjoes's Avatar
bobbyjoes
ok will do thanks guys for advice
GalvTexGuy
2014-2024 Touring Models
11
Aug 20, 2019 08:35 PM
Neil
May 31, 2017 11:00 AM
RoadHog659
Apr 10, 2014 10:00 PM
bugzapper
May 20, 2011 08:08 PM
woodworking1
Jun 2, 2010 11:28 PM
