Quick Question
Old Jan 6, 2013 | 01:13 PM
NickW's Avatar
NickW
Default Quick Question
I just put on some new grips and levers on my '12 Blackline. Prior to doing so I could start my bike in gear and now I have to be in neutral. I read another thread a while ago that said there was a sensor somewhere near the clutch cable when you are adjusting it but I cant find it now. Did I screw something up or did I accidentally fix a problem?
Old Jan 6, 2013 | 01:20 PM
spydyr's Avatar
spydyr
There's a sensor in where the lever goes. Either you pinched a wire when putting the control back on, or you bent the sensor push-in when you put on the lever.
Take off the lever and see if the sensor is still in place. That's probably what happened.
Old Jan 6, 2013 | 01:24 PM
NickW's Avatar
NickW
Thanks, Ill check it out.
Old Jan 7, 2013 | 02:00 PM
mswing1234's Avatar
mswing1234
There is a switch installed in the housing behind your lever. It's called the Clutch Interlock Switch. When you pull and hold the lever in, it depresses the switch and you may start the bike in gear. It's very common for those not aware that it's there, to break the switch or to pinch the wires when reassembling the switch housing, while doing a grip change. I broke my switch and was throwing error code B1154 (Clutch Switch Input Short to Ground). Other than not being able to start in gear and the error code, no big deal. If it is the switch, they are over $60 at the dealer if you do the install. I did mine. It's a special switch so finding a form/fit replacement might be difficult. If it's the wire, you're going to have to get in there and have a good look at them, cut out the offending area , re-solder and heat shrink.
Old Jan 7, 2013 | 05:35 PM
NickW's Avatar
NickW
Thanks, It was the switch. The lever just wasnt hitting the button. A little JB weld to make a nipple on the lever worked just fine.
Old Jan 8, 2013 | 12:11 PM
mswing1234's Avatar
mswing1234
Great! I missed where you stated that you replaced the levers. Apparently they are not an exact replacement. JB weld....whatever works.
Max Headflow
Milwaukee Eight (M8)
38
Nov 10, 2020 08:17 AM
mswing1234
Jan 18, 2016 05:05 PM
ghost183
Screamin Eagle CVO Models
Jul 29, 2015 06:35 PM
clarkchriston
May 3, 2013 08:23 PM
rgm
Jan 4, 2013 08:02 AM
