Oxygen 02 sensor ?
Old Jan 8, 2013 | 06:38 AM
brettnbama's Avatar
brettnbama
With a pc 5, you won't run them. There are little plugs that you will stock in the wiring harness where the sensor normally plugs. They just trick the ecm into thinking the sensors are running correctly. You can leave the 02 sensors in your exhaust with the wiring hanging, or you can remove them. If you remove them, you need to get a set of plugs for the holes...
Jeffrey Hatch
Apr 24, 2019 09:27 PM
UKNixter
Dec 14, 2016 08:47 PM
leafman60
May 9, 2016 08:54 AM
wardski76
Sep 24, 2012 08:17 AM
DFTL20
Jun 19, 2006 11:06 PM
