Header pipes cherry red
Old Feb 6, 2007 | 12:23 AM
ultra2006's Avatar
ultra2006
Default Header pipes cherry red
Put, VH long shots on buddys bike, with PC111, big sucker, cranked it up and the header pipes turn cherry red, but they also did it with stock ones, is this normal for them to get so hot, on a 07 Heritage.
Old Feb 6, 2007 | 12:39 AM
mentor70's Avatar
mentor70
Default RE: Header pipes cherry red
I would venture to say that you are lean....possibilbly too lean.
how was the bike running. freeway speeds, around the block? idling in the driveway?
a full thottle dyno pull could turn them red, but just riddin around id say somthing is wrong!
Old Feb 6, 2007 | 03:16 AM
In Memoriam Citoriplus's Avatar
May our Moderator Rest in Peace
Somethings not quite right there, I have to agree with mentor70, its running way too lean. I would richen up the mixture a bit throughout the range to start with. Then maybe get it to a dyno for a bit better fine tuning.
Old Feb 7, 2007 | 12:18 AM
ultra2006's Avatar
ultra2006
It was at idle sitting on the table after the install, but it was doing it also before the changes.
Old Feb 7, 2007 | 05:28 AM
Oldtimer of NM's Avatar
Oldtimer of NM
ORIGINAL: ultra2006
If you didn't have a big fan blowing air over the engine, the pipes (and engine) can heat up in a hurry. As long as it doesn't happen while riding above 20 MPH, it's probably normal.
Old Feb 7, 2007 | 09:08 AM
Grey Biker's Avatar
Grey Biker
Fan or no fan pipes turning cherry red is heat.
freakchile13
Exhaust System Topics
Jun 6, 2013 03:31 PM
jlasoftail
May 31, 2011 12:20 AM
09NightsterVB
Jun 1, 2010 01:27 PM
Spanish Flyer
Oct 25, 2007 12:25 AM
StreetBobBen
Jul 19, 2006 01:28 AM
