With 10lbs of force
Table 1-6. Rear Belt Deflection
Figure 1-33. Checking Belt Deflection
FXSTIFLSTCI
VEHICLE FLSTNlFXSTD FLSTFIFXSTBI
FLSTSCIFXSTC
With motorcycle on jiffy
1/4-5/16 in. 9/16-5/8 in.
stand without rider or
(6.4-7.9 mm) (14.3-15.9 mm)
luggage
Vehicle upright with rear 5/16-3/8 in. 11/16-3/4 in.
wheel in air (7.9-9.5 mm) (17.5-19.0 mm)
Without the tool a shop uses the rule of thumb is to take the belt between Ur thumb and finger and adjust it so U can turn/twist Ur belt about 45* in the middle of it at the bottom.
It'd still be a good Idea to get a Shop Manual if u plan on doing very much of Ur own work.
