Rocker Wheel install help
Old Feb 9, 2013 | 11:15 AM
TRUSTNOBODY's Avatar
TRUSTNOBODY
I have a 18x8.5 custom wheel with a 250 tire, belt is a ⅛ away from tire. Used my stock spacers , i think your hubs are wrong. It took colorado customs 3 trys to get mine right
Old Apr 1, 2013 | 07:26 PM
Hicksjay's Avatar
Hicksjay
Yep, my hubs are 1/4 wider than my rocker ones. Just went to a sprotor to free up space. 12 hours this weekend couldn't get the spacers right. Ill be done Friday night.
Old Apr 1, 2013 | 09:45 PM
Alain's Avatar
Alain
Looking forward to seeing it.
Old Apr 1, 2013 | 11:11 PM
jeepcj33's Avatar
jeepcj33
i have an avon 250 with the heartland kit and shotguns with no problem on my rocker
Old Apr 1, 2013 | 11:48 PM
Hicksjay's Avatar
Hicksjay
I think the 250 is okay, I think my hub/wheel is the issue. It is 1/4 inch wider than my factory one.
Old Apr 2, 2013 | 05:46 AM
Rodzilla6's Avatar
Rodzilla6
I have a 260 vee rubber on the back of mine and it just barely touched the belt. We left the bike on the lift, started it in first gear and let the wheel spin slowly. We took my belt sander and just tweeked the sharp edge that touched the belt and it has been fine. Going on 6k and no issues. Good looking wheels you have. Hope it works out.
Old Apr 3, 2013 | 02:48 PM
TRUSTNOBODY
I ran a tape measure inside the stock hub and measured from bearing to bearing on the original wheel. U need the same exact measurement on the new wheel for everything to work and be aligned. On my new wheel there was a ˝ adapter behind the drive pulley to kick it out a ˝" u need that because your stock wheel is ˝ smaller than your new wheel
Old Apr 8, 2013 | 12:32 PM
Hicksjay's Avatar
Hicksjay
Hey there.
Kind of have 2 threads here so lets merge them...
https://www.hdforums.com/forum/softa...in-switch.html
Optimizer
Aug 21, 2017 02:35 PM
BMWHD
Wheels/Tires
Dec 14, 2015 09:45 AM
Wynchester
Wheels/Tires
Jul 3, 2014 07:15 AM
DragonSlayer08
Jul 23, 2011 12:59 PM
davidbrinknyc
Nov 18, 2010 09:58 PM
